2001 Lincoln LS Logo
Posted on Sep 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 lincoln ls v8 i have a rattling noise coming from the water pump or its a componant real close what could this be
Josue Almodovar
Level 3:
  • Master 298 Answers
  • Posted on Sep 10, 2009
Josue Almodovar
Master
Level 3:
Answers
298
Questions
0
Helped
156213
Points
1047
Hi if it's coming from the water pump then it's the water pump but to be sure you can use a piece of garden hose and put it close to where you hear the noise and listen to it through the hose
2001 Lincoln LS V8 3.9. Where is my motor ground cable please?
Question edited for clarity and turned around.
Question moved to model category.
This says on the rear of the inlet manifold.
https://www.google.com/search?q=2001+Lincoln+LS+V8+3.9.+Where+is+my+motor+ground+cable
How to Take out he Gas Tank/ Door Trunk Panel
locating fuel pump and jet pump 2001 lincoln ls - YouTube
? 2:46
www.youtube.com/watch?v=09KMTlVgQAc
Jan 8, 2013 - Uploaded by mifanointed1
locating the fuel pump and jet pump of the 2001 Lincoln LS. ... I have a question: Did you find that the fuel pump seems to be stuck/screwed in the tank? ... I'm in the process of replacingmines now and I'm having a little trouble kinda .... How to do a Water Pump Installation for a Ford 4.6L V8 - Advance Auto ...
My 2001 lincoln ls v8 has a delay wheel turn likewhen you turn your wheel sharp the steereing wheel gets loose feeling and the wheel dont turn as good as it suppose to be any ideas what it might be?
Front steering / suspension is only as good as its weakest link. There are many components working together that can be problematic here is a list of liikely culprits & things to check, tried to put easy stuff first:
  • tire pressures
  • steering fluid
  • worn/loose steering rack
  • tie rod ends
  • column u-joints
  • suspension - struts, joints, bushes components & integrity
1helpful
2001 lincoln ls 3.9 v8 a/c not working is cuttin off when i on ac
Most likely a leak & low on refrigerant
Need a shop to leak check,evacuate,make repair,
and recharge
2002 lincoln ls fuel pump electrical cutoff switch
The inertia switch should be in the trunk behind the trim panels.
You may need a pump relay.
2003 lincoln ls v8 rattles when first started
It's your Cat. I promise you I hads the same thing happen to mine and was told it was just my heat shild but if that was the case then it would raddle all the time I thought then when I got a new cat it all stoped
4helpful
How to change a fuel pump on a 2001 lincoln ls v8, 3.9 liter
Remove driveshaft,them fuel tank. You have two pumps in tank
My 2001 lincoin ls gauge goes up to the h and then come back down
you probably have air trapped in the system. Have dealer or radiator shop bleed system.
I assume your cooling fan is working.
what engine v6 or v8?
SECTION 303-03: Engine Cooling 2001 Lincoln LS Workshop Manual
DESCRIPTION AND OPERATION Engine Cooling The cooling system components include the:
  • block heater (optional)
  • cylinder head temperature sensor
  • fan blade, fan motor and fan shroud assembly
  • radiator
  • pressure relief cap
  • degas bottle
  • radiator draincock
  • water pump
  • oil cooler (optional)
  • water thermostat
The water thermostat:
  • controls the engine coolant temperature.
  • allows quicker engine warm-up.
The degas bottle:
  • provides a location for system fill.
  • contains coolant expansion and system pressurization.
  • provides air separation during operation.
  • replenishes the engine coolant to the system.
The fan blade draws air through the radiator to help cool the engine coolant.
The fan motor:
  • operates only when the engine is running.
  • will not operate when the engine is off.
The engine coolant flows:
  • from the lower radiator hose to the water pump.
  • from the water pump to the engine block and the cylinder heads.
A closed water thermostat returns the engine coolant to the water pump. An open water thermostat allows the engine coolant to flow to the radiator.
Unsatisfactory coolant materials:
  • Alcohol-type antifreeze does not provide adequate water pump lubrication.
    • has lower boiling point
    • reduced antifreeze protection
  • Alkaline brine solutions will cause serious engine cooling system damage.
The cylinder head temperature sensor provides a signal to the temperature gauge.
  • will invoke failsafe cooling.
The optional block heater:
  • electrical heating element is installed in the block cooling jacket.
    • uses a standard 110V (220V in Europe) electrical supply
  • keeps the engine coolant warm during cold weather.
The auxiliary water pump (3.9L only):
  • provides heater coolant flow boost.
  • has a secondary function of providing engine-off cooling.
Where do I find the crank sensor on my 2001 lincoln ls V8, and could this be the problem if when I turn the key I get the lights and everything else it just wont try to start. Other times it starts up and...
could be but it could also be the fuel pump,the immobiliser,the auto choke,the sensor in the water jacket for the auto choke ,could be anything and you wouldnt know .
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
