Question about GE Profile JP930 Electric Cooktop
Why the oven want come on ?
F7 is beeping on screen.
    Problem Solver:
  • 5 Answers
Check the starter. the piolet!! if eletric check plug wire and see if the outlet works
Posted on Sep 10, 2009
Testimonial: "Thanks!I moved in a new house and the plug here is a 4 peg plug mine is a 3 peg. So i witched plugs you think that might be the problem?"
What is the solution if my oven beeps?
Hello friend, thank you for your inquiry!
I understand that your door is locked and you have error "F5E1" showing on your range. I would perform a reset on your appliance which can be done by flipping the household circuit breaker off for roughly ten minutes. If that does not correct the issue and you continue to receive the error "F5E1" I would contact a professional to come out and repair your appliance because it could be an issue within your UIB (user interface board) or main control panel. Hopefully this helps. -Matt
Sep 15, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
Mar 27, 2013 | LG Ranges LRE30453ST 30 Inch Freestanding...
Trying to set time, got stuck on wrong time, can't bake my turkey F90 displays when I press bake and a loud steady beep comes on until I press Stop. so I need 2 questions answered thanks
According to your service manual page 9 an F-90 is maximum oven door unlock time exceeded.
Here is your SERVICE MANUAL
This video shows how to check the door locking mechanism:
This shows how the electric oven high voltage portion of your oven works:
Jan 01, 2011 | Kenmore Cooktops
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 25, 2010 | Jenn-Air JED8430 Electric Cooktop
I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 26, 2010 | Frigidare GLEC30S8C 31 in. Electric...
Alarm code FC and F7, everyting works but the alarm keep come back.
Hi There
I have found the code for you and hope help this helps out.
F7 - E1 Common switch wire is defective Common wire (+5VDC) to latch switch, and to door switch is shorted to chassis ground or neutral. A double oven will have two of each switch and one common wire.
1. Check connections at control and at the latch switch and door switch.
2. If all connections are good, then check the individual switches as outlined for the F5 failure. 2 Digit Failure CodesThank You for writing to Fix Ya.
Best Regards Richard
Feb 18, 2010 | Cooktops
F7 Error
This error happens if a function (key) is stuck. Usually the one that is used most often or the one that someone poked using something pointed.
Change the touch pad if it is separate from the clock (ERC or EOC) or change the whole clock if they are one unit
May 05, 2008 | Jenn-Air JED8430 Electric Cooktop
-F1-
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board.  I would need the entire model # on sticker on the oven to see what parts are on this one.  If the touch pad is separate it will have a ribbon that goes from it to the board.  Unplug that ribbon, if the code goes away then the touchpad is the problem.  If the code stays with the ribbon unplugged then the control board is bad.  Make sure power is off to unit when touching anything!
Oct 12, 2007 | Cooktops
GE Profile JP930 Electric Cooktop Logo
89 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
