Question about Symbol LS4004 (ls4004i0007705z) Handheld
When connecting Symbol ls4004-1000 via USB, data is not captured while scanning. How can it be resolved?
    New Friend:
  • 65 Answers
LS4004 does not connect directly to USB it needs a STI adaptor which needs to be programmed. please contact me for instructions. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Posted on Oct 20, 2009
HP C309a will not scan on Mac 10.7.5
So, why would that surprise you? Mac is much different than Windows!
May 12, 2017 | HP Photosmart Premium C309A All-In-One...
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
Data loss while scanning a 2d label. it is not capturing entire contents
If you are using data wedge to scan then it needs to be configured. I can provide steps necessary for this request. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Sep 28, 2009 | Symbol Motorola MC3090 Handheld Computer
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
Symbol HotShot LS2106 sounds like it's scanning, but no display
If you are using a USB to PS/2 converter on the end of the USB cable then it won't work. You will need to get a PS/2 cable made for this scanner. I can supply you with one if you need it.
Jul 03, 2009 | Symbol Hotshot LS2106 Handheld
Could not active it the scanner on the MC9090
The link works for me DataWedge provides a convenient mechanism for non-scanning aware applications to receive data from embedded or connected data capture devices. It allows the user to capture data into any application that accepts keyboard input. It supports four types of Data Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers and Serial Data Input. It provides user with text/hex data formatting and prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
make sure some security software is not blocking your access
Jun 22, 2009 | Symbol MC9090 Barcode Scanner
LS 1902 AND USB CONNECTION
Scan the Set all defaults barcode from the product reference guide and set the scanner to use USB again if required. This should sort out your problem.
Mar 18, 2009 | Symbol Cobra LS1902 Handheld
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Symbol LS4004 (ls4004i0007705z) Handheld Logo
1,054 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
