Question about Lenovo ThinkPad R51
Can not turn on the wireless device. I've checked the BIOS and it's enabled. I've tried the Fn F5 key and it doesn't even access the wireless controls.
  • tllewellyn May 11, 2010
    Can you clarify further? Can you perform any detection of wireless networks? What OS are you running this Laptop on? Please provide as specific information as possible
This happened to me, you need to reinstall the drivers for your wireless adapter, these should be able to be found when you hit my computer and then C drive.. there is generally a partition that says drivers
Posted on Sep 13, 2009
Tip
Lenovo G430/ G530 Function keys
<p><span>The following describes the features of each function key.</SPAN><br> <p><b><span>Fn + F1: </SPAN></B><span>Put your computer in sleep mode.</SPAN><br> <p><b><span>Fn + F2: </SPAN></B><span>Turn off/on the LCD screen back light.</SPAN><br> <p><b><span>Fn + F3: </SPAN></B><span>Shift to other connected display devices.</SPAN><br> <p><b><span>Fn + F4: </SPAN></B><span>Switch between wide screen and normal mode.</SPAN><br> <p><b><span>Fn + F5: </SPAN></B><span>Enable/disable the built-in wireless device feature.</SPAN><br> <p><b><span>Fn + F8: </SPAN></B><span>Enable/disable the touch pad.</SPAN><br> <p><b><span>Fn + F9: </SPAN></B><span>Play/pause Media Player playback.</SPAN><br> <p><b><span>Fn + F10: </SPAN></B><span>Stop Media Player playback.</SPAN><br> <p><b><span>Fn + F11: </SPAN></B><span>Skip to the previous track.</SPAN><br> <p><b><span>Fn + F12: </SPAN></B><span>Skip to the next track.</SPAN><br> <p><b><span>Fn + Insert/NmLk: </SPAN></B><span>Enable/disable the Numeric keypad.</SPAN><br> <p><b><span>Fn +Delete/ScrLk: </SPAN></B><span>Enable/disable Scroll Lock.</SPAN><br> <p><b><span>Fn + PrtSc/SysRq: </SPAN></B><span>System request.</SPAN><br> <p><b><span>Fn + up/down arrow: </SPAN></B><span>Increase/decrease display brightness.</SPAN><br> <p><b><span>Fn + right/left arrow: </SPAN></B><span>Increase/decrease computer volume.</SPAN><br> <p><b><span>Fn + PgUp: </SPAN></B><span>Move the cursor to the head of the line.</SPAN><br> <p><b><span>Fn + PgDn: </SPAN></B><span>Move the cursor to the end of the line.</SPAN>
on Jan 19, 2011 | Computers & Internet
Wireless capability Switch is off on dell vostro 1400.Is there another way to turn on switch.
There are three ways to toggle the wireless switch on/off, 1st, Fn + wireless button (F2 or F5), 2nd, the wireless switch on the side of the laptop, 3rd, it can be enabled or disabled under BIOS setup (Tap F2 when turned on the laptop).
Jun 30, 2011 | Computers & Internet
Need help with which Fkey to push on the Elitebook in order to turn on my wireless network capability. I was told it was the F5 key but having no luck.
It must had been hard unable to connect wirelessly with your device. It's ok, F5 is part of it. But just for me to make sure i'm leading you to the resolution kindly follow the instructions below.
  1. Check the wireless switch. Make sure it is switched to the icon of a computer with signal on both sides.
  2. Press FN (usually on the left side of the space bar on the keyboard).
  3. While holding FN down, Press F5.
  4. You should see a notification on the lower right hand side of the screen that wireless is enabled.
Check your wireless capability. Thank you for choosing FixYa!
Apr 07, 2011 | Computers & Internet
I CAN NOT TURN ON THE INTERNAL RADIO OFF IN BIOS TO CONNECT WITH WIRELESS FOR IBM R 60
If you want to use Fn+F5 to enable the feature specified in IEEE standard 802.11, the following device drivers must be installed on the computer beforehand:
  • ThinkPad Power Management driver
  • OnScreen Display Utility
  • Wireless device drivers
OR you can follow this link:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-62714
Please rate this , if it works for you
Thanks
Sandeep
Mar 09, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
I have wifi on my computer but i do not know how to turn it on.
To enable or disable wireless networking hold down the Fn key and while holding down the Fn key press the F12 ket and this will enable/disable your wireless. Hope this helps
Jun 24, 2010 | Dell Inspiron 700M Notebook
One laptop cann access the internet via the dlink wireless router, the other laptop can not even see the network.
On the "other" laptop, is the wireless adapter "enabled" or "disabled" ?
Look for either a button, or a slider, or a sequence of keys ("hold down FN and press F5") to enable the wireless adapter.
Then, click Start
Click Control Panel
Click System
Click Hardware
Click Device Manager
Click the '+' to the left of the 'Network Devices'
Do you see the wireless adapter listed?
Is there any RED or YELLOW tags on top of the device's icon?
If so, double-click the icon, and click "Reinstall Driver".
Jan 05, 2010 | D-Link Computers & Internet
Can't enable Dell Wireless 1390 WLAN Mini-Card
I had the exact same problem and went through the same steps that he did. It was only when I searched for a physical wireless switch (on the left side of my Dell D630) that the problem was solved. I didn't even know it was there and must have inadvertently knocked into the off position.
Dec 12, 2009 | Dell Inspiron 6400 Notebook
Where is the wireless switch for ibm t42 laptop i have tried fn and f5 nothing works
There will either be a switch on the side of the machine or it will be fn and one of the funtion keys, look for an image like this:
http://hpshopping.speedera.net/www.shopping.hp.com/shopping/images/overview/wireless_black.jpg
Nov 26, 2009 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
588 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
