Question about Hardware & Accessories
How do i replace one
How do i replace the timer
  • Michael Thomas
    Michael Thomas May 11, 2010
    Hello there can you please tell me what this timer is for it is not posted
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    I'm assuming you are making refference to a washing machine? Please clarify if you will, what make and model it is and if it indeed IS a washer or not.
    Sergeant:
  • 384 Answers
Buy one from the local hardware store.
Posted on Sep 10, 2009
Do i need to power down to change the back up battery
If this is ordinary residential timer, you can replace battery without changing anything.
Just replace battery.
Most timers will hold some or part of the memory during battery changeover... frequently losing no programming if battery change is done quickly, and battery was not completely depleted, and timer is still functional.
If timer function is not restored after battery change, reset timer fully and then reprogram.
If battery change and reset does not work, then timer is probably gone bad.
Most modern timers have reset button, but some require a 2-button sequence to reset.
Other modern timers have a 'battery' but the battery is built into the circuit board and thus not replaceable ... it is rechargeable, like a capacitor ... but when it fails .. the timer needs to be replaced.
Timers with replaceable batteries are generally not functional after exposure to freezing temperatures for several day, but the non-replaceable type generally have wider tolerance for temperature variation.
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/Programmable.html
Gene
Water Heater Timers Save Money
Mar 23, 2015 | Hardware & Accessories
Replace backup battery
Posted under orbit timers... product not identified
Many timers today have a backup 'battery' that is actually a capacitor located on the circuit board.
Generally the battery is not replaceable and is specific to the circuit board design and model of product.
Product manuals and manufacturers call it a battery because it works like a battery to preserve settings during brief power outage.
If the timer has a replaceable battery, then there will be a small door located somewhere on timer that can usually be popped open using thumb or small tool.
There are some timers that have a replaceable battery... this applies to wall timers, box timers, timer modules, and sprinkler timers etc... and this is very useful for some applications because the timer can operate loads independent of using voltage.
Disadvantage of replaceable battery is failure due to cold weather or bad battery connection. Advantage of capacitor-type battery is low cost and high reliability.
http://waterheatertimer.org/Override-thermostat-with-programmable-timer.html
http://waterheatertimer.org/Gardena-timers-and-manuals.html
Gene
Mar 12, 2015 | Orbit Hardware & Accessories
Digital display stopped working electronic timer
Identify timer.
Replace battery.
Do not use battery-operated timer in cold environment... look for temperature range when selecting timer.
Mechanical timers will work in cold temps.
Or buy another timer to replace defective timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
h
Nov 23, 2013 | General Electric Hardware & Accessories
How do I charge timex digital timer 12/874
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
2) Usually you plug timer into outlet for 1/2 hour to charge internal non-replaceable battery. Other timers have replaceable battery. Always reset timer before programming. If timer display does not show with charged, or new, battery, then try timer on different outlet, and/or replace timer.
3) If timer does not show on link above, add comment and include photo or clear description of timer.
Dec 05, 2012 | Timex EASY TO SET TIMER BY TIMEX
Why is my timer runnung backwards
Timer is not identified.
Analog timers have clock motor.
If the gears strip out, then timer can run backwards.
Some timers have replaceable clock motors, such as Intermatic and Tork box timers, and pool timers.
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
While small plug in timers generally do not have replacement parts.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 19, 2012 | Hardware & Accessories
I have an Aube 3 way wall switch timer that has failed. I have another timer (utilitech in-wall timer) that has a black, red, white and ground wire. Not sure how to wire it.
Utilitec can only replace single-pole switch.
Open following link for typical Utilitec single-pole wiring:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aube timer has internal battery that runs clock mechanism and does not require neutral wire.
The Aube battery lets timer replace single-pole or 3-way switch.
Utilitec timer does not have battery, so clock mechanism requires neutral wire, just like plugging in electric clock.
Without battery, timers like Utilitec can only replace single-pole switch.
Open following link to see list of timers that can be used for 3-way:
http://waterheatertimer.org/Aube-timers.html#3-way
When installing 3-way timer, the timer replaces one 3-way switch but other 3-way switch remains.
The remaining 3-way is rewired to accommodate the specific timer being used.
SOME brands of timer cannot replace either 3-way switch, but instead can only replace the 3-way that receives hot wire from breaker: Read manual before selecting timer.
Note: Battery-operated timers can be used for 3-way application, but cannot operate in cold environment.
Aug 13, 2011 | Aube Technologies Aube 7-Day Programmable...
Is the Woods 59028 Programmable Timer Switch Light Almond a 3 way switch?
Woods 59208 is single-pole timer.
Open following link to see list of timers used for 3-way application:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
When replacing 3-way switch, some timers can replace either switch. For example Aube and GE.
Other timers can only replace switch that receives power from breaker. For example Intermatic.
The timer replaces only 1 of the 3-way switches.
The other 3-way switch remains.
But in all cases, the remaining 3-way switch has to be rewired to accommodate the timer.
3-way timers cannot replace 3-way switch wire-for-wire.
3-way timers mimic 3-way operation. When 2 of the timer wires are connected, the timer reverses programming. When those two wires are disconnected, the timer programming resumes. So off becomes on, and on becomes off.
The remaining 3-way switch has to be rewired so that switch connects and disconnects the two timer wires that mimic 3-way operation.
Aug 08, 2011 | Woods 59028 Programmable Timer Switch...
Is the woods 59028 a 3 way switch?
How do you wire a digital in-wall timer to a 3-way circuit?
First, the timer has to rated for 3-way application.
Not every timer works for 3-way.
Open following link for some timers that work for 3-way application.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Next thing is to read instruction manual carefully.
Since 3-way switches come in pairs, the timer replaces one of the switches, and then the other switch remains.
Some timers can replace either switch, and some timers can only replace the switch that receives hot from breaker.
In all cases, the remaining 3-way switch must be rewired to accommodate how the timer works.
May 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
My hotpoint condenser dryer keeps tripping the trip switch
Replace the switch, or the whole control/timer assembly.
If it keeps giving you troubles after replacement, you will need to check the electronic control module (small box) inside the appliance.
Insert model number here to get schematics and replacement parts.
Oct 10, 2008 | Dryers
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
