Question about RCA HD52W59 HDTV Projection Television
I have a rca hd52w67 projection tv and the screen looks like it is concaved,has three lines across the top and looks like it is in 3d. What is wrong with it?
  • 60 Answers
The convergnce amplifiers have failed.
This is a common old-age problem.
This requires replacing the convergence amplifiers and possibly resistors and fuses. A repair shop would charge $300-$400 to repair.
If you are tech savy or know someone who is, thae parts will cost around $40.00. Search this site for specific instructions.
Good Day,
-Dan
Posted on Sep 10, 2009
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
Blue streak across the top of the television and colors are reflecting making it look 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jun 26, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I have a projection tv that the pictures ghost and the red and green and blue do not line up on the screen. There is allso lines across the top of the screen and are red,blue,green. Looking at the screen...
You have a convergence problem. I have a tip which explains what this is, how to repair it and where to get the parts at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics . Let me know if this is not the problem or you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
It is like looking at 3d in all three colors. i
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
May 30, 2010 | RCA D52W19 52" Rear Projection Television
Tv looks like it is in 3D
Sounds like your convergence amp board has gone out and will need replaced. If you feel like giving it a try yourself this web site has them fairly cheap and they have an 800 line if you need help determining your board number.
http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD52W59 HDTV Projection Television
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
My HD52W67 has concaved picture
This is a convergence problem and can be repaired relatively easily. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Dan
Jun 25, 2008 | RCA HD52W66 Projection Television
RCA HD52W67 convergence menu missing from menu and has a b,r,g line going through the top of the menu and it looks like every thing is in 3d
that model doesnt use the two STK ICs that most other models use. Try replaceing fusw fl231 . The schematics arent easially available for any RCA TVs unless they are the older projection ones. I would recommend checking with this link and seeing if they have the service manual or perhaps they can get it, if you leave an email with your model number.
http://servicemanuals.vstore.ca/
Jun 06, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
288 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
