Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 3200 storage not recognized by pc It has been working fine for the last two years but now my PC (and 3 others) cannot recognize it.
    Problem Solver:
  • 15 Answers
I have two that failed in similar time: 2 years. You may be having a problem with the power supply. My symptoms and solution follows.
Symptoms:
green LED is on on the PS 3200
was recognized as Maxtor PS 3200 by Windows XP when plugged in
drive letter was not assigned
in device manager, error code 10 was listed: device failed to start up
no spinning sound coming from the hard drive
checked the power supply with a voltmeter, and was near 11V
Solution:
found another 12V supply from a Seagate FreeAgent drive and plugged it in.
The spin-up sound was evident this time and the drive was recognized with no problems.
I am currently searching for a permanent replacement power supply. I've found the specs on the original at the following website.
http://www.libertye-online.com/servlet/the-1642/new-APD-I.T.E.-POWER/Detail
12V 2A, positive inner pole, 2.5mm ID and 5.5mm OD
I would not recommend buying the same one from ADP; many people are having problems with them failing after about two years.
NOTE: there's more info on the Seagate Knowledge Base website. You can view my submission there as well.
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=1258
Cheers!
snack9907
Posted on Sep 16, 2009
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear. Known as "The Click Of Death"
Posted on Sep 10, 2009
What does blinking green light on Maxtor 3200 mean?
Typically, if your seeing that green light, it means you don't have enough power from your power supply. You may need to disconnect some of the other components for the drive to boot up. Ultimately, if you want to continue using the new drive, you'll need to replace out the power supply with a larger one.
Good Luck
Sep 07, 2014 | Maxtor Personal Storage 3200 (U01E200) 200...
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have windows XP home edition and just reformatted computer. now the computer will not recognize the Maxtor 3200 personal storage device
Until you put an Operating System, Windows, Linux etc, on the formatted drive, it will NOT recognize the drive, it will not recognize anything...
Feb 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
There is a troubleshooter that describes steps for these symptoms on Seagates Knowledge Base website.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=188697
Aug 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Computer not reconizing Maxtor Personal Storage 3200
i think you should replce the USB connector cable because tha tmay be  the problem
if you have any more questios pls do post back
Jul 24, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor and vista
Try some other USB device (memory-stick, printer, camera) in the USB slot in the Vista computer, just to "prove" that Vista will recognize _any_ USB device connected to that slot.
May 31, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
319 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
