Question about GE Ovens
Screen shows F-1 flashing . I had a clock failure previously with a F-7 trouble code . I ordered another from Sears and installed it today . Everything worked OK after the new clock assembly was installed. Then about an hour ago the oven began to beep and the code F-1 appeared
    Guru:
  • 310 Answers
We usually see F7 caused by a failure in the keypad (stuck key) and F1 caused by a failure in the control board (clock). This seems opposite to your experience. I would suggest first to power down the oven, unplug the keypad from the control board, power up the oven with the keypad unplugged. Give it some time (may take as much as 30 minutes or so), if no F1 error then problem is likely the keypad. If you still get an F1, then the problem is the control board and you should return it. If you still have trouble post your model number.
Regards,
www.fixyourboard.com
Posted on Sep 10, 2009
Display shows PF-time of day flashing on Frigidaire range.None of the buttons respond. Rene
Try unplugging it to reset the main control board witch most of the time its your clock.then push enter.if don't don't work then your clock (main control is bad .or if it has a touch pad it could be bad.call repair clinic .com at 1-866-822-0890 or 1-800-269-2609 and order parts there.they can tell u how much
Nov 08, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Getting an error message from the oven, F2:E3
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
FixYourBoard.com
May 08, 2011 | KitchenAid KEMC378 Electric Double Oven
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
Nov 29, 2010 | Frigidaire Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Oven door will not lock to clean
hi, these two codes together are signaling a EOC failure. the electronic oven control has failed and you will need to replace the EOC/clock. it is unable to initiate any commands because, it in a frozen state.
You can try to reset this control by unplugging the entire unit for 5 minutes. if the control continues to not reaspond to your commands, replace the EOC.
please rate and god bless:)
Apr 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Oven has error E1 F1 will not work
F1 - E1
EEPROM checksum error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
Nothing works but the clock and shows F7
I had this on my stove for months and it also didn't work. Finally, Sears changed the computer board and no trouble since then -- five years ago@
Sharon in Covington, La
Oct 15, 2008 | Kenmore 30169 Electric Single Oven
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
114 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
