Question about Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
Motor feels bound and hard to turn... DYNAMO PaFab Pool Pump.. motor can be turned by hand.. but just hums when turned on..
  • 279 Answers
If there is a capacitor on it, you could replace that. If there is no capacitor the starting switch is probably broken. If you are not used to working with electricity, either have someone qualified work on it or...BE CAREFUL!..God luck...Lee
Posted on Sep 10, 2009
Waterway pool pump is humming but fan is not turning
Shorted motor windings, can you move the turbine when turned on or does it feel like it is being held in place. WARNING!!! do not try with your hand, use a tool. Possible capacitor, but I would suspect motor to turn slowly.
Apr 02, 2013 | Waterway Pool & Spa
Pool pump plug is black and is humming
bad capacitor or motor or blockage in impeller
Jun 19, 2012 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
Pump does not turn on it just hums
bad start up capacitor turn off and try spinning shaft then turn back on if doesn't work replace motor or pump
Apr 03, 2012 | Pentair 1 hp Dynamo Pump
Pentair dynamo 340210 was running fine, cleaned out skimmer basket turned it back on and all it does is hum. The impeller is not clogged and turns fine by hand. Any solutions?
you have probably hit a dead spot on the motor - try turning the motor by hand and then turn it on - maybe it will kick it.
dangerous to do it while the power is on but some people have had luck doing the same thing while the power is turned on.
US Parts Center
Aug 21, 2011 | Dynamo ABOVEGROUND POOL PUMP - 1HP -
I purchased a new 3/4hp Emerson pool pump installed it and the only thing it will do is hum.
OUT THE BACK SIDE OF THE MOTOR IS A SLOT IN THE SHAFT FOR A SCREWDRIVER , SEE IF YOU CAN TURN THE MOTOR OVER(BREAKER OFF !) YOU MAY HAVE BOUND THE IMPELLER OR IT COULD BE SET FOR 230 VOLTS AND YOU ARE RUNNING IT ON 115VOLT.....
IT MAY HAVE A BAD START CAP OR THE SWITCH MIGHT NEED CLEANING. THESE EMERSON MOTORS CAN BE HARD TO WORK ON DO TO THE HUGE AMOUNT OF PLASTIC PARTS
Jun 20, 2010 | Hayward 3/4hp Super Pump Inground Pool...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Dynamo pump is locked--just hums
Try turning the motor from the back. Remove the end cover and turn the shaft. If it still hums the motor will need to be replaced.
Apr 27, 2009 | Pentair Dynamo 3/4 Hp Above - Ground Pool...
Dynamo ABOVEGROUND POOL PUMP - 1.5HP - Logo
235 people viewed this question
Top Dynamo Pool & Spa Experts
Jay Finke
Jay Finke
Gil Shultz
Bosse Photos
Are you a Dynamo Pool and Spa Expert? Answer questions, earn points and help others
