Question about HP iPAQ H4150 Pocket PC
Ipaq H4150 Bios upgrade failed now I have a screen showing HP invent logo and cannot turn off or reset the Pocket PC
  • seanmylne Dec 15, 2007
    I had a prblem with my ipag 4150 - couldnt get past the screen alignment - upgraded the bios - no it is stuck on the boot screen "HP invent" - i have hard reset - still the same issue.
    any help on this would be good.
    Sean
Have you used a Vista PC as the host machine? ROM updates can only be done from a Win XP or 2000.
Hook the iPaq to an Win XP or 2k PC, install active sync first, and then get the ROM update again. Run the Rom Update Utility and it will recognise the iPaq and will update it correctly. :)
Posted on Jan 31, 2008
I downloaded the upgraded ROM on my IPAQ 910 (P/N FB050AA#ABA) and experienced problems. Now the unit cannot even load. When turned on, it shows a page with HP logo with these information: RUU..., HP...
why not ask < HP>>>>???
its old, almost nobody uses these now....
are you going to spend money on this thing?
why change the BIOS? ROM best is not to unless you know
the BIOS update fixes a known issue you have, no issues stated.
https://h30434.www3.hp.com/
Jul 17, 2017 | HP iPAQ 910 Pocket PC
Hi I treid to do a ROM update on my HP iPAQ 4150. The update stopped and the screen now shows 1.05H and 1.02 and only the HP logo. Does not go anyfurther. Furthermore the iPAQ is not recognized by...
I ran into the same issue with a H4150. Pull the main battery and let it sit without the battery for a while; a few seconds is not long enough. I let it sit for about two minutes and that was long enough on each of the four times I needed to recover from a failed ROM upgrade last night. This reset the H4150 and it then initialized like it was just out of the box; all data and settings were reset to original. Some troubleshooting procedures indicate you should not use a USB hub for this process. That did not work for me-the ROM upgrade still breaks the connection just after getting started. But at least pulling the battery got the iPAQ back to a useable condition. My next test will be to try it from an old PC with Windows 98 and USB 1.1 or 1.0. Maybe the brief disconnection is normal and a fast PC with a modern OS may not be as forgiving to brief upsets. Just as the ROM update really begins (after all the handshaking), the iPAQ briefly drops the connection and that's when the update fails, it just takes a little longer for the software to say 'hey-I've lost communication with the iPAQ...'
Oct 03, 2010 | HP iPAQ H3835 Pocket PC
I was trying to update the Bios when my pocket pc went to a screen that has the word "Serial" at the top, a hp blue logo in the center with the word invent underneath it and at the bottom it has a v1.08. I...
Not a problem it happens just go to hp.com download the bios driver and use it on windows xp it will not work with anyother windows and run it with your ipaq connected to the pc. This will reinstall the complete bios software and bring it back to factory.
Aug 10, 2010 | HP iPAQ H2200 Pocket PC
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Go to Settings-Connections-Connections-advanced-Network Card.
You will see all available wireless networks in your area. Double click the desired wireless network and tap connect. Note whether the desired network has been connected.
Hope this help,
Harit
Jun 26, 2008 | HP iPAQ H4150 Pocket PC
Ipaq bios upgrade
try a hard reset. hold down green and red and power same time push the reset button located by the charging port
Mar 27, 2008 | HP iPAQ HX4705 Pocket PC
PDA stops during Bios upgrade
If you have tryed hard reseting it then
You need to get your hands to a working flash of your pdas operateing system, can be hard to find, I was lucky I found many for mine.
After you have the software and the tools needed, most likely the software will have instructions so it shouldnt be hard to do.
After a successfull reFlash of the operateing system everything should be fine.
If you where playing with the bios you need to flash a working version to it. If you cant do it youself I recommend takeing it to a professional, the bios chip can be hard to reprogram.
Feb 06, 2008 | HP iPAQ HX4705 Pocket PC
Problem
Hi, I have same problem. After upgrade bios to version 1.10 my ipaq h1940 don`t start windows. When switch ON appears HP logo, time line go to end, and ipaq stay block. No possible switch OFF and no starting windows.
Nov 16, 2007 | HP iPAQ H1940 Pocket PC
Ipaq h4150 failed rom upgrade (white Screen)
Pull the battery out, wiat for a minute and reinstall the battery and turn it on.
May 12, 2007 | HP iPAQ H4150 Pocket PC
HP iPAQ H4150 Pocket PC Logo
388 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
