SHOULD GET I FIX OR SHOULD I REPLACE IT. I UNDERSTAND THAT SOME K/A MIXERS HAD THE HOBART MOTOR. I HAVE A KSM5PSWW SERIAL NUMBER WJ0602624. IS THIS A HOBART MOTOR?
It sounds like your motor is okay if it is trying to drive the unit, it may be that one of the gears inside the unit have broken or chipped. this can cause a lot of damage quickly and should be disassembled right away and cleaned. another source of this noise could be that your motor fan blade which is attached to the motor is hitting the armature field winding. you could easily detect this if you have the back panel off and turn your mixer on This motor is not a Hobart motor simply because its made by Whirlpool and Hobarts motors for smaller mixers are mostly no longer available as where the whirlpool motor is still available.hope this helps
I am having problems with my k5ss kitchenaid mixer. The problem happens when i tryed to even mix...
(More)
I am having problems with my k5ss kitchenaid mixer. The problem happens when i tryed to even mix butter and sugar the paddle would not rotate under a load. It works fine with without any products in the bowl but as soon as i try to mix anything it just stops mixing. It does not smoke or heat up at all. All of the different speeds do work.
KEHC309JSS05 door shows open. indicator says ''close door''. The door IS closed. New oven, been in...
(More)
KEHC309JSS05 door shows open. indicator says ''close door''. The door IS closed. New oven, been in storage for years. BRAND new off showroom floor. Any idea?
K5A 30 year old mixer will only operate at lowest five speeds. stays at speed 5 as control is moved...
(More)
K5A 30 year old mixer will only operate at lowest five speeds. stays at speed 5 as control is moved upwards to ten. Over the past several years it wouldn't operate at speed 9 or 10, and just recently it gave up speeds 6, 7 and 8. Is it clogged with flour and powdered sugar?
My KitchenAid mixer does not turn off. I'm sure it has something to do with the switch which does...
(More)
My KitchenAid mixer does not turn off. I'm sure it has something to do with the switch which does not stay in the off position. Who can I get to fix this?
