Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Superba kitchen aide refrig red light for water filter wont go of
Replace water filter about 3 months ago
light is on and wont go off
  • 725 Answers
You just need to replace the light switch on the filter control panel. I hope this helps you out.
Posted on Sep 10, 2009
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
Is the filter behind the kick plate on the Kitchen Aid Superba made in 1998?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
Where is the filter located on the KSR52206WH00 model 98 Kitchen Aid Refrigerator?
I would suggest you look inside the refrig compartment and get the correct model #.
The one you put in the question does not exist.
Kitchen Aid superba model # KGRT607HBTO Bake function is not working although igniter was replaced a couple of months ago. Broil feature is working.
Pull the temp sensor and with a multimeter, see if you get a reading of around 1100 Ohms at room temperature. Post back the results.
Oct 21, 2013 | Kitchen Ranges
Problem with water and ice
My kitchen aid superba sie by side stopped making ice. I've changed the water filter and did the trouble shooting options in the book. Everything else is fine. Can you give me any suggestions
Mar 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
IT IS ABOUT 4 YRS OLD AND THE WATER STARTED TO
I would not advise using bleach. I would disconnect the pipe from both ends and blow down it, either by mouth or air gun to ensure of no blockages. You should poor away at least 10 cups of water after changing filter to ensure clean fresh water.
Dec 15, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
WATER STOPPED WORKING
is it a kit-aid refrig???? if so i would look to the wire harness under hinge, 7 or 8 wires runnig through hinge creating a pinch point and shearing wire(s), only solution offerd by kit aid is door replacement (harness not available, molded into door) but at close to $700 for a new door some well placed solder mends the connections quite well( wire nuts to big)
Jan 16, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba
You indicator light on your fridge is set on a timer. If you never took a single glass of water it would go on after six months or so. It is just an aide to remind you. To replace it, firmly turn counterclockwise about a quarter turn with a little pressure pulling down or out depending on the location of the filter. You need not turn off water. Replace with new one.
Sep 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
161 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
