Question about Sony SLV-798HF VHS VCR
Code 3L117C ???
Tape will not eject and the code 3L117c comes up on the display. If we turn the unit off for a time the tape will eject when turned on again. This code also appers after we rewind a tape and we try to eject the tape.
  • Anonymous Jul 22, 2008
    DOES ANYBODY HAVE A SOLUTION FOR THIS PROBLEM R IS IT FAIR TO SAY THE UNIT IS READY TO BE DISPOSED OF?
    New Friend:
    Problem Solver:
  • 8 Answers
The only "solution" I know of is to avoid using rwd or ffwd without play (use "searh" instead). If you do that the pinch roller mechanism gets stuck on old(ish) Sony VCRs. Annoying.
Posted on Nov 26, 2013
    Problem Solver:
  • 5 Answers
None that I could find. Trash time for this Sony
Posted on Aug 01, 2008
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
When tape is inserted the unit starts beeping and I have to eject tape. Tapes will not play, rewind, fast forward or record? How can I fix this?
The beeping indicates that an error has occurred and that the unit has been disabled because operation could damage the unit further. To determine what the problem is- Turn unit off. While holding the STOP button, turn back on and continue to hold the button for 8 sec, then let go. Press display and you will get an error code on the monitor, for instance, C:21:00 error code (the most common code I get) indicates a condensation problem. If this is the code you get then leave the unit open in a dry place for 24 hours or so, and it should dry out the dew sensor and clear the code. The unit will hold up to 6 error codes in the order that they occur, rotate the wheel to cycle through the codes. Codes are displayed as - C:XX:XX. If you get a code other than C:21:00, then google the code,(Sony C:XX:XX) and the description will probably come up. Good luck.
Jun 28, 2009 | Sony EVO-250 Hi8 VCR
Will not display picture or eject tape.
most of no signal means dsr 11 or similar machines have dirty heads. When they get dirt sometimes, you can´t play a cassette and the machine turns off (with the cassette in).
I´ve tried several times to reload the cassette and I manage to make it work again.
with the cassette in and the machine off press at the same time power and fast forward.
When in fast forward press play and your head should be starting to be clean (takes 4 o 5 minutes
to get a clean picture). Normally the machine gives a code error like if it was a loading problem but
not nearly related
Mar 13, 2009 | Panasonic Televison & Video
Sony DSR 45P error code C3125
Press the power butten several times while holding down the eject button. It will solve your problem and clear the error. If it not then there is something wrong with your reel motor or the circuitery which deals the reel motor. You must consult your nearby sony service center.
Rajab Ali
Mar 08, 2009 | Sony DSR-45P DV / Mini DV VCR
Tape will not eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
Dec 18, 2008 | Sony Handycam CCD-TRV608 Camcorder
Hi 8 Tape Will Not Eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to eject the tape. You may be getting an error code that indicates the reels are not turning for some reason. You can assist the reels turning as the tape is ejected if you stick a small plastic pick or a toothpick into the reels to assist the reels turning and then you may be able to remove the tape.
Chris (ziraffa)
Oct 17, 2008 | Sony Handycam CCD-TRV608 Camcorder
Cannot record or play
The C31:22 message indicates that one of the motors inside has failed to turn. This is a safety message and the unit will eject the tape to prevent the tape from getting damaged. Unfortunately, there is little that you can do other than get the unit into a service shop. The repair of this will require dis-assembly of the unit. I would suggest that you either get an estimate for the repair or send the unit to Sony using one of their fixed rate repair options.
Dan
Sep 26, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Jun 04, 2007 | Sony SLV-660HF VHS VCR
Sony SLV-798HF VHS VCR Logo
530 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
