My Screen looks 3D, it just happened out of no where. What is the problem is it the lamp?
  • 10,594 Answers
Let me know model and brand of TV to find out reason of 3D look picture.
Usually this kind of problem occurred in rear projection TV that has 3 CRTs to produce picture and it happens when convergence out ICs got bad.
Once I have your TV model and brand, I would be in better position to provide you solution.
Thanks.
Posted on Sep 10, 2009
Mitsubishi hd 1080 display looks like 3d
its the motors in the tv that line up the mirrors to get you a picture , can be fixed , but I bought a new one when this happened to me as lamp was due to go
Nov 06, 2013 | Mitsubishi WS-65311 65" Rear Projection...
There is red and blue lines around screen and images. (Almost looks like it should be 3d). Does this mean it needs a new lamp/bulb? It is only 6 years old. What is the cost for the part? Thank you
If model number is as listed (46f500) it does not use a lamp or bulb but has three picture tubes.
3d means the two convergence chips in the set have failed.
It depends on if you can solder etc, not a very expensive parts cost (under 30 dollars)
Can you solder?
SD TECH
Sep 17, 2011 | Hitachi 46F500 46" Rear Projection...
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 60vf820 hdtv. The pictures appears to have a greenish tint but not all of the time. Sometimes the screen looks dim and sometimes appears normal. I have had the tv for 4 years and replaced the lamp...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | Hitachi UltraVision 60VF820 TV
Getting 3D effect in picture is there a way to adjust lamps to fix problem
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 25, 2010 | Sony KP-43HT20 43" Rear Projection...
Concentrator will not line up colors making screen look like 3d
May 28, 2009 | Sony KP-51WS510 51" Rear Projection...
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
My rear projection television looks like it is 3D
replace the lamps and then run the synch routine from the main menu. unfortunitly with the expense of the lamps and the low price to replace projection tvs it might not be worthwhile to fix but just replace.
HINT wait till after new years, LCD large screen tv sold about 35% of what was expected during xmas so they will be real real cheap after the 1st of the year
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
