Question about AOpen AX4PER 845PE P4-533MHz DDR333/5.1/AGP4X/LAN/ATX Motherboard
Ax4per with 1.8GHz does not recognize new 2.8GHz processor. Socket 478. BIOS is current. Is it not plug and play?
  • 4 more comments
  • scotdonovan6 Sep 10, 2009
    Thanks. MoBo is jumperless,and AOpen says it does. perhaps the CPU is DOA.
    Hi Wayne, I do have that PDF file. I will follow the steps you listed and tell you what happens.
    The system does not POST, the CPU fan comes on, but then nothing. When I swapped the old CPU back, I found that the NEW CPU did not generate any heat at all.
    I am able to access BIOS every time the 1.8 CPU is in.
    The new CPU is INTEL P4 2.8 GHz 1MB 533 478 Desktop CPU SL7E2.
    I notice that Core voltage is 1.25 - 1.4. With the 1.8G in, BIOS is set to 1.75v. Should I lower it, then shut down, install, and restart?
    Reset CMOS. Still no POST. I'm going to try another CPU. The specs from Intel say this CPU SHOULD work. Tomorrow I may try booting with the 1.8GHz into BIOS and manually setting. I think I tried that already, but I'm kinda blearry eyed.
    President:
  • 1,901 Answers
Does it POST and can you get into the BIOS? You need to set the FSB to 133MHz and the Ratio to 21x.
(I am assuming you did install the CPU correctly and installed the fan.)
If you can't get into the BIOS, you may need to reset it using JP14 on the motherboard.
Turn OFF power. Remove the AC power cord. Hold the power button in for 5 to 10 seconds. (This is done to discharge any capacitors.) JP14 normally is on Pins 1 and 2. Place the jumper on Pins 2 and 3 for approx. 10 seconds. Then place it back on pins 1 and 2. Connect the power cord and turn it on. This will set all the BIOS settiings to default and you should be able to set the FSB and Ratio.
Do you have a manual for the MB? you can get it from:
ftp://ftp.aopen.com/pub/manual/mb/ax4per/ax4per-ol-e.pdf
Thanks for using Fixya.
Wayne
Posted on Sep 10, 2009
Testimonial: "Wayne knows his stuff. VERY helpful."
  • 3 more comments
  • Wayne Mineard
    Wayne Mineard Sep 10, 2009
    That link for your manual is messed up. (Thanks Fixya!)
    Try this one:
    Wayne
    BTW....Yes your MB should support a 2.8GHz processor. That is the max though.
  • Wayne Mineard
    OK. Fixya insists on putting a prefix on ftp links. Grrrrrrr!
    If you click on the link, you will get a "Page Not Found". Just delete the "http://www.fixya.com/" in the url and hit Enter or GO. That will work.
    Sorry for any confusion.
  • Wayne Mineard
    If you reset your BIOS, I'm not sure what the defaults will be for the CPU. For the 1.8GHZ the FSB is 100MHZ and the Ratio is 18x.
  • Wayne Mineard
    Actually your MB is supposed to have a voltage auto-detect system.
  • Wayne Mineard
    The specs say the SL7E2 is a 533MHz FSB processor so yes, it should work.
    President:
  • 1,015 Answers
Your board has a 533 mhz FSB and the Pentium 4 2.8Ghz uses a 800 mhz FSB. The socket for both chips are the same but the FSB is different speed. You will need to upgrade *********** board to a board compatible with a 800 mhz FSB Like the one on the link. It has a 533/800mhz FSB. Yours only has 533mhz.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138079
  • 36 Answers
Either it does not support this speed or there is often a jumper setting on the mobo that allows you to switch to different speeds. Try changing the jumper (if available), but most likely the mobo does not support this CPU.
How many processors supports my motherboard p4m80-m4 biostar ? specially can it support dual core processor...??? also tell me about supported graphics card please help me>>>???
You have a very old motherboard here. It only supports the older AGP 8x video cards. Good luck finding one of those anymore that is worth the price, and don't expect anything you find to be new in box. This is probably where your HD video woes start, although the board was never designed for the higher frame rates that HD requires to be viewable.
As far as the processor goes, this board has the Socket 478 for Intel processors. There are no dual-core processors that are supported by this socket. Here is a link to an article that shows what processors are supported by the socket. Be advised, however, that depending upon the BIOS revision on the board, some of these may not work properly, if at all.
Socket 478 Socket mPGA478B
Really, if you want to view HD, it's time for a real upgrade.
Aug 24, 2016 | Biostar P4M80-M4 Motherboard
Pls provide new processor's will match KOB 845GL NDSMx board
It uses a Socket 478 for an Intel Pentium 4 processor up to 400MHz. You are somewhat limited being this a older (in computer yrs) model. This is the fastest and for some reason the cheapest I could find.
http://www.aliexpress.com/item/Intel-Pentium-4-2-8-2-8G-Socket-478-512K-2-8GHz-400MHz-Free-Shipping/491972022.html
Oct 03, 2012 | Computers & Internet
I need to know what kind to buy for this board. the processor heatsink ASRock ge pro-ht
Socket 478 is a very old socket type, it's been around for nearly a decade. The only processors that work with this socket are Intel's Northwood Pentium 4 and Celeron processors, which are now far surpassed in performance. I would definitely recommend buying a new motherboard for whatever you were going to use this one for. If you are set on this motherboard, however, read on.
Many computer hardware companies have stopped carrying Socket 478 processors. You will most likely have to buy one second-hand. A quick search on Amazon will give you a few buying options (all used) for around $20-$30 US.
Due to the age of the processors, you will probably need to purchase a heat sink seperately. This heatsink is $20, will fit Socket 478, and has very good reviews, but of course feel free to use any heatsink as long as it fits Socket 478: http://bit.ly/hk6yZ5
If you also need memory, be sure it is DDR 333/266, as this is the ONLY type of memory that the 2 memory slots on motherboard will take (maximum 2GB of memory). You can find list of DDR 333 memory in varying capacities here: http://amzn.to/fOGbeV
Mar 22, 2011 | Asrock GE Pro-HT R3 Socket 478 Motherboard...
Right i need the size or model for the cooling fan that all intelboard mode E210882
The Heatsink/Fan combo is based on the processor socket used.
After a few search hits, I have seen E210882 on Intel based motherboards, that use two different processor sockets.
The Socket 478, and the LGA 775 processor socket.
The socket for the Socket 478 has the pin holes. The Processor has the pins. (478 of them)
http://en.wikipedia.org/wiki/Socket_478
The socket for the LGA 775 processor socket has the pins. The Processor has the pin holes. (775 of them)
http://en.wikipedia.org/wiki/LGA_775
Identify which processor socket you have, buy accordingly as to the Heatsink/Fan combo.
One example of a Heatsink/Fan combo for an Socket 478 processor socket,
(Only Intel uses the Socket 478 for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=578161&CatId=795
One example of a Heatsink/Fan combo for an LGA 775 processor socket,
(Only Intel uses the LGA 775 socket for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3302824&CatId=1588
Remember to observe Anti-Static Precautions, Thoroughly clean the top of the Processor's case, and aplly fresh new thermal paste.
(A Processor is the most susceptible hardware component to Static shock)
[ Example of thermal paste,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503 ]
If you would like advice on how to properly clean the processor's case, properly apply thermal paste, and/or what Anti-Static Precautions are, post in a Comment.
Nov 07, 2010 | Intel Motherboard
I have an old desktop pc, ASUS P4S533MX, Intel socket 478, with SiS PCI IDE Controller.. ( IDE ATA/ATAPI ) 1. Can I upgrade the Radeon 9250, 128 Mb DDR 64-bit to something better? 2. Is it...
well...ASUS P4S533MX- Intel socket 478 allow maximum processor upgrade from 3.2 GHz upto to 4.2 GHz.
for upgrade the Radeon 9250, 128 Mb DDR 64-bit ....whole moherboard along with new processor has to be replaced. an expensive deal..
better to buy new motherboard+compatible processor of ur choicce
Sep 19, 2010 | Intel ASUS P4SC Socket 478 Pentium 4...
I need the motherboard manual for p4m266823x
I need driver VIA P4M266-823x, help me please!!!
Jun 10, 2009 | Computers & Internet
I am using intel pentium4 2.4GHz processor with intel 845 motherboard, now i would like to upgrade it with intel 865 motherboard, is this possible?
it defend to your processor is for socket 478 motherboard and you going to upgrade *********** to intel 865 it supposed to be socket 478 too also if not your processor is useless because socket 478 mother is already phase out the new mother now using socket lg775 for intel dual core and quadro core processor
Jun 02, 2009 | Intel D845GVSR Motherboard
No display
No, it is a motherboard processor socket problem, repairable only with a new motherboard. Can you give me motherboard details to compdoctor2005@btinternet.com
Dec 13, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
AOpen AX4PER 845PE P4-533MHz DDR333/5.1/AGP4X/LAN/ATX Motherboard Logo
130 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
