Question about Sanyo DP32746 32 in. LCD Television
Popping sounds from tv
While looking at the tv it makes a popping sound through the speakers. I checked all of the cable and audio connections
  • 1 more comment
  • roise98 Dec 20, 2007
    i hear popping sounds on my lcd tv
  • Anonymous Jan 25, 2008
    I have the same problem. Only the popping sounds are really loud. There doesn't appear to be a specific pattern. Does anyone know why?
  • torquemada64 Mar 03, 2008
    I have the same popping sound coming from my tv. All the connections are tight. The sound is intermittant, not all channels, not everyday. This has occured on two different tv's hooked up in the same place. I even unhooked the cable box to see if it was in the transmission, but it continued.
    Scholar:
  • 163 Answers
You are getting a spike through the audio circuit for some reason.. Does the screen stay 100% Normal when it happens? And is it a steady timed thing or intermittent?
Posted on Feb 29, 2008
MY PICTURE IS GREAT,BUT NO SOUND. WHAT CAN I DO TO FIX IT?
Make sure TV is not muted.Make sure the TV is not set to SAP (secondary audio protocol)Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.If using an "S" video cable into an input on the back of your TV, these cables carry no sound, just video, so make sure you connect an audio cable too.Hook up an external device to the "TV audio out" input. This will be the test to see if it is a TV circuit board malfunction or the speakers are faulty in your TV.If you are connected to a satellite box, use the included remote and go into the "menu". Check to make sure sound settings are set correctly.
Read More: http://removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/#ixzz3lTeW6isH
Sep 11, 2015 | Televison & Video
Sound problem
Check what type of cable is connecting your sat box to your TV
If it is via a red/green/blue cable, make sure you also have an additional red and white audio cable connected, and select YPbPr (or component audio) in your TV's menu
Apr 22, 2008 | Zenith R56W36 56" Rear Projection...
I get a popping sound on my tv when I change Chanel's
Check all of your audio and video connections to make sure they are seated(connected properly). After doing so,if you still have the popping sound try lowering the volume and see if the popping noise lessens or gets worse.If the noise goes away then you may have a problem with the speakers,either in the tv or in an external sound system if one is connected.
Feb 19, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
Im trying to hook my insignia flat screan tv to my mitsubishi M-VR900 recevier the tv has plug for audio out and recevier has a tv audio in red/whit plug and i have 2 speakers i have on the front spearker...
Go into the onscreen menu of your TV, find and select the audio options. Make sure the audio out on the TV is enabled (this might be an automatic feature and might not be displayed -it depends on your TV model). Next make sure your receiver is working and (if it is so equipped) make sure your speaker switch is enabled.
Make sure all of your cables are working. You can do this by switching out the cables one at a time for ones you know are good.
Make sure no headphones are plugged into your receiver or the TV -this usually turns off your audio signal to any speakers.
Your TV remote may be equipped to control the volume output of the external audio out signal. Some TVs automatically turn off the internal speakers when you hookup or select an external audio output. turn up the volume on both (your TV and the Mitsubishi).
Does the Mitsubishi work on other sources (DVD, radio etc...)?
Remember to double check your cable connections -audio OUT from the TV to audio IN into the Mitsubishi. Reversed connections can damage your TV and amplifier electronics.
What model is your Insignia? Some are equipped with digital outputs which, if your receiver is so equipped as well, can send surround sound (home theatre) signals to your receiver. These can be orange-colored rca jacks or optical jacks. They do not send analog audio signals.
Once all the cables are double-checked, (double-check your speaker connections!), turn on your receiver, TV and signal source (cable, satellite DVD etc...), bring the volume control (both on the Mitsubishi and the TV) up to nominal levels. You should hear sound.
One more thing:
Make sure your speakers work. You can try them on another amp or simply touch the speaker terminals with a 9-volt battery (the speakers should move in or out depending on the 'phase' of the connection).
Hope that helps.
Nov 26, 2011 | Audio Players & Recorders
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
No sound
Make sure that you do not have the TV muted and the volume isn't at the lowest setting. If there is still no sound look behind the TV to see if anything is plugged into the sound out. Having something plugged into the sound out sometimes turns off the sound in the TV's built in speakers. Also go into the sound settings and double check that the internal speakers are not disabled, or that the tv is not set to audio out only. Next make sure that you have the audio cables correctly connected, or if you are using HDMI, there are no audio cables to worry about. Make sure the sound cables are also connected correctly to the device that the signal is coming from. If you did all that, check to see if your device is outputting sound in the first place. Go into the settings on your device to see if the sound is disabled, and that the output you are using is the one being used for sound output. If all of these steps don't work you should take your TV into a repair shop to be fixed.
Jul 28, 2011 | Televison & Video
Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Apr 30, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Cracking popping type sound coming from front and center speaker
if u are trying to connect the audio of ur tv as input to flow out from the home theater; this is a common thing; u need to replace the audio cable that connects the tv to 3565 with a good quality cable
Apr 01, 2009 | Philips HTS-3565 Theater System
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Sanyo DP32746 32 in. LCD Television Logo
314 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
