Question about Husqvarna Chain Saw 20" Bar
Husqvarna 51 chain brake wont open
Cant get chain brake to unlock
    President:
  • 2,220 Answers
This thread covers it quite well. It is applicable to all models.
http://www.fixya.com/support/t1195376-chainsaw_brake_locked_husqvarna_455
HTH
Lou
Posted on Sep 10, 2009
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
I have a chain saw 55 husqvarna and while the motor turn he stop suddenly often of the time when I put the brake and the motor is truning slowly he stop
Check to make sure the brake binder is not engaged...which is the same as saying: check and make sure the kickback brake handle is fully cocked. The handle should be oriented rearward towards the forward hand grip. If it is forward, pull it back stongly until it lockes in place. (Hint: also make sure the binder is released/brake cocked always before attempting to remove the brake assembly from the saw drive engine subassembly.)
Oct 04, 2014 | Husqvarna Chain Saw Models 51, 55
Husqvarna 51 file size
Several bar and chain combinations fit the 51 model saw. If your saw runs an H46 / H80 or H81 style chain you will need a 7/32" (5.5 mm)
If you are running a H21 style chain you will need 3/16" (4.8mm)
May 02, 2014 | Husqvarna Chain Saw Models 51, 55
I remove the chain brake and bar cover from my 51/55 Husquarna saw and cannot get the cover back on the saw. The brake band is to tight to fit over the clutch assembley and I cannot figure out how to get...
Hi, the chain brake has most likely been activated while removing the cover. Place the cover in a vise where the bar nuts tighten up to and pull the chain brake lever backwards towards where the handle bar would be. It should click back and stay back. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
HUSQVARNA 455 RANCHER - HOW TO UNLOCK CHAIN BRAKE WHEN COVER IS OFF THE SAW?
Go to http://www.milacalawn.com/parts.asp and look for the bolt that hold the brake.usually the bolt is located in the chain plate that has a large groove in order to adjust the chain.
Oct 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
Dec 29, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna chain brake
You'll have to release the brake with the cover off the saw. You just need to find a way to brace it well enough.
If you really can't do this, then it suggests your chainbrake is faulty, of ath the very least not adjusted right.
Sep 18, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
442 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
