Question about Whirlpool Washing Machines
Wont advance to rinse
Whirlpool washer wont advance to rise even after fitting a new timer
    President:
  • 2,187 Answers
You may want to inspect further the unit such as if there is still water remaining after the wash. You may have a drain pump that is not working properly or the water level sensor is not working correctly. The water level sensor normally appear as a float device. In some models they show up as a tube that goes out to the control unit.
Posted on Sep 10, 2009
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
Washing machine does not advance to the "rinse cyle." It continues to agitate indefinately.
if your machine will not advance out of ajitation mode you have abad timer assy, it is not field servicable it gets replaced as an assy, new timer run you betweeen 50-90 bucks
Jan 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
May 19, 2009 | Whirlpool Washing Machines
Whirlpool Washer stalls out on rinse cycle
This is likely a lid switch problem. They tend to get weak and work sometimes and sometimes not. When it stalls like that try pushing down on lid and see if it kicks in. If so you need to replace the lid switch
May 11, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Stops on rinse cycle
    I had this exact same problem. Check and see if the screws to the door hinges are tight and if any are missing. I had one screw missing and it would not allow the door to be level and thus not be able to push the switch all the way down. This tells the washer the door is closed and if it is not closed it wont continue with the rinse cycle.
    Sep 15, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washing Machines Logo
    Dan Webster
    Dan Webster
    Sal DeAngelo
