Question about Volvo Vehicle Parts & Accessories
I have a 2002 S60 T5 with approximate 70k Miles. About 2 months ago I got an alram/siren warning message-took it to a dealer (first time using this dealer) as we moved from the west coast and have tried several dealers on East coast without finding one we trust and feel is competent--when in CA we loved the dealer (had several volvos always happy with service) replaced alarm and siren. Dealer said diagnostics indicate a battery drain caused by a bad PDM, dealer did not have PDM in stock so work wasn't done. Car currently will not start w/o a jump, took to an independent volvo mechanic who has been recommened--so far he has confirmed a 9V battery drain but can not locate source--says PDM is good--he removed every fuse indidually and drain continues-- he is still working on trying to locate problem but looking for ideas, help.....
  • srosenberg11 Sep 10, 2009
    wouldn't the electric draw end when fuses were removed if it was the trunk or glovebox light????
    thanks
    by the way would a battery needing replacement show a 9v drain?
    President:
  • Volvo Master
  • 1,564 Answers
You may have something as simple as a glovebox lamp or trunklamp that is staying on when the lid is closed.Easy to check those before you start getting too deep. The reason I suggest these two is that I worked for Volvo as a tech and found this situation after ripping my hair out for hours, more than once.You might also just have a battery that has done it's service and now wants to retire. If you have power seats take a quick under the front seats from the rear and check for a possible soda can or other form of debris that may have squeezed a wiring harness. Lastly an alternator regulator which is intergral with the alternator can cause a draw if it goes faulty. Disconnect the tickler harness(pull off connector) from the alternator and see if you've still got a draw. I'll be following your results, I'm intrigued by your situation. Good luck my friend, Dana
Posted on Sep 10, 2009
  • Dana Newcombe
    Dana Newcombe Sep 10, 2009
    Not always depending on what side of the circuit the fault is on.Please continue to check the other options mentioned heretofore,Thank you, Dana
Transmission warning light
The TCM may be a problem. Why didn't you ask them (the dealer) for more information??
Jun 05, 2013 | 2002 Volvo S60
I have a 2002 Honda EX coupe with about 70k miles. The check engine light came on a few weeks ago. About a week ago, it started to blink periodically. The last time the check engine light came on (about 1...
Check engine light comes on because engine computer has detected a fault. It could be anything, from a cheap sensor to an important component out of specifications, to a service reminder. Most shops (not necessarily Honda dealers, ) have the diagnostic equipment to hook it up to your car and tell you what is wrong, before fixing anything. Usual rates for this diagnostic is below $100, including quote for repair.
Mar 31, 2010 | 2002 Honda Accord
2002 Volvo S60 (T5) The break ligth warning
This has to do with the anti-lock brake system. It will be fine without it, but if you want it fixed get it done at a dealer not a shop. It will cost a lot more but the repairs will be done right and will last longer.
Jul 29, 2009 | 2002 Volvo S60
Oil change
well its always recommended every 3000 miles to change the oil if you are using mobil1 full synthetic oil then every 5000 miles transmission i recommend every 45000 miles 60000 mile should be radiator fluid,power steering,fuel filter if trans hasnt been done then transmission
Jul 06, 2009 | 2002 Volvo S60
My s60 has just been serviced 6 weeks ago .the warning light is now on amber and says that the engine system service is required ,what does thios mean ?
The dealer (or whoever you took your car to) forgot to reset the maintenance reminder light. Take it back and have them do it.
Hope this helps.
Bilal Hassan
Clarksville, MD
Jun 11, 2009 | 2002 Volvo S60
2002 S60 - Low compression on cylinder #2 and cracked coils issue
coils crack over time with age and wear. it may take several hundreds of dollars to replace, but definitely necessary, and no gaurantee that its the only problem you may have. the low compression could be several different things. but you will have to decide if its worth fixing or replacing the car. you will start paying for repairs a little at a time every couple of months, or ante up and have a major service done to fix and replace everything.
Apr 29, 2009 | 1997 Volvo 960
Volvo 2002 S60 T5 climate control
no power on the heater, ac , defroster ect, panel. this panel has many controls, the power to this unit is absent.!!
Aug 04, 2008 | 2002 Volvo S60
Does the Corolla 2003 model have a timming belt or chain?Does the water pump has to be changed at 70K miles? Thanks. Adrian
Adrian,
Until 2002 Toyota's had a timing belt. After 2002, Toyota's have a timing chain. Manufacturer/dealers recommend replacement of the timing chain at about 90,000 miles. I've talked to several mechanics - including the dealer - about the cost of changing out the chain. The lowest price I found from a very reputable mechanic is $260-270. He told me that if I brought in the part, he'd reduce the cost. The dealership was almost double!
Re: water pump: I haven't found anything that stated it must be changed at 70K miles. Hope this was helpful.
Lady V
Jul 21, 2008 | 2003 Toyota Corolla
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
