Question about Black & Decker Drills
The motor fell apart and need to put it back together 18volt b&d cordless drill
    Sergeant:
  • 384 Answers
Get a large plastic bag and put all the pieces in to it. Shake bag for 10 minutes. Look into bag, has drill reassembled? If not, shake again for 20 minutes. If this fail to reassemble drill, throw bag into land fill, and buy a new drill. Thank you for your support of BD.
Posted on Sep 10, 2009
Craftsman drill model 315
If it just fell apart the do not waste your time putting it back together as it will only fall apart again when you are working. Just get a new chuck.
Jun 28, 2013 | Drills
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
Drill fell and broke now trying to put it back together gears and all,require help
Unfortunately on that model they do not service any of the transmission parts separately so there is no exploded view. Here is the parts diagram. You may end up having to buy a new trans assembly.
DeWalt DC987K diagram
Aug 10, 2012 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
When i drill with my 18volt cordless, and the bit catches it makes an awful grinding noise inside the drill, its not the adjustable clutch set low. its set on drill?
Your speed switch is between gears, pull the trigger lightly and slide the speed switch back and fourth until it is fully engaged. Also turn the clutch setting all the way down then all the way back to lock it is not uncommon for them to get dodgy.
Cheers,
Kevin
Mar 23, 2010 | Dewalt DC6PAKRA Heavy Duty Xrp 18volt...
I have an 18 volt 1/2" drive cordless impact wrench made by DeWalt and when I pull the trigger the motor runs but not the anvil?
Sounds like you have a gear broke that runs from the motor to the shaft. Take it apart and check it out. easy to put back together. atleast you will know for sure and may fix it while it's opened up.
Jan 18, 2010 | Dewalt DW056 18 Volt Cordless Impact...
How can I take a part my dewalt 12 volt drill
Hi there, Remove the battery and sometimes the screws on the drill casing are a torx instead of phillips so you will need a set of torx screwdrivers. Once you have removed the screws from the casing be very carefull when pulling the two casings apart, try to leave the chuck, motor and switch assembly in one half of the casing as it makes it much easier when trying to put it back together.
Jan 01, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Fell apart!!
the transmission comes in assy. all u can do is to match the gear & test every small installed. if it's dw997 see www.erplacementparts.com for your guide how to re-assemble.
if dw988 trans diagram see similarity on how to put it back.
Aug 16, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Makita 18volt 6347 cordless drill
then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Mar 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
50 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
