Question about GE Profile JTP18 Electric Single Oven
I have a ge profile oven and F7 is appearing where the degrees usually appear. Nothing will work on the oven
  • GE Master
  • 3,361 Answers
You have a stuck keypad. You can try pushing every pad several times at random to try and clear it. If that does not work,you have to replace the keypad control.
Posted on Sep 10, 2009
Control panel doesn't work
F7 indicates either a stuck key or the main control has failed. Try depressing each button one at a time checking for a stuck key. If each one retracts I would replace the main control this is more likely the problem. There easy to replace. If you enter your model # at www.appliancehelponline.com you can get diagrams and illustrations of your specific model.
May 27, 2010 | GE Profile JTP56 Electric Double Oven
Oven flashing F7 serial number is jgrp17bew288
F7 code
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced
Good luck and please rate 4 thumbs for the free answer
Mar 10, 2010 | GE Profile JT910SASS Electric Single Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
The oven doesn't work. F7 appears on the control panel.
Door lock release fault · Bent pull-rod for door latch
· Bad door latch solenoid
Feb 15, 2010 | Ovens
Ge profile performance double oven. getting an F7
F7 is a stuck keypad/button.
Push all buttons at random several times each. This will sometimes un-stick a stuck button.
If that does not work the keypad control will have to be replaced.
Jan 16, 2010 | GE Ovens
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 15, 2008 | GE JKP15 Electric Single Oven
GE profile light comes on by itself and then get f7
http://www.repairclinic.com/0078.asp#GE5, this site will give you the code and if your mechanically inclined you can do it your self ,but if the warranty isnt exspensive you might want that,but it is the keypad
Jul 07, 2008 | GE Profile JT912 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
415 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
