Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
Compressor not comming on somtimes / freezer staying cool not cold / fridge cold
  • 396 Answers
Turn the termostat to high, check the following morning. If unit is not cooling you need to replace the compressor. However, before replacing compressor make sure all the fans are working.
Posted on Sep 10, 2009
My kenmore fridge with bottom freezer, model#596.785.83801. Both fridge and freezer won't stay cold. Fan on and lights are on. Help!!
Check to see if the compressor in back is running. It could need a new compressor start device. If it is running it could need a new compressor. The compressor cooling fan could be stalled and the compressor is overheating.
Sep 26, 2014 | Refrigerators
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
Jun 03, 2012 | Hotpoint Refrigerators
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
The freezer is not freezing. Is cold only.
The problem which you mentioned is related to faulty/ weak compressor.--------- I will explain with more detail.------
Jun 28, 2011 | Refrigerators
Not getting or staying cold.
If its not getting cold or freeze then this problem is related to weak compressor.The compressor is the part which controls the cooling of whole refrigerator.When the compressor gets weak,the cooling and freezing both will will get effected. But if the freezer is getting friezed but fridge section is not getting cold then-its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Fridge and freezer not getting cold
If it was layed down to move and not let sit for a while before using it again it would not work. Somtimes leaving in off and let it settle will straighten it out but not all time. The oil in the compressor get into the cooling lines and blockes the freon. Other than that, check the condenser coil which are near the compressor. They should be warm when the compressor is runnin. If they are not warm there is a compressor or freon problem.
Sep 01, 2009 | Refrigerators
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
89 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
