Question about HP Pavilion dv4000 Notebook
Several keys do do nothing when used. - HP Pavilion dv4000 Notebook
  • 1 more comment
  • dorsia Sep 10, 2009
    the following letters won't type
    g
    H
    and backspace
    There was nothing spilled on the lap top
    I poped the G, H, and Backspace key off and found nothing out of the ordinary
  • muebe May 11, 2010
    Be more specific...What keys are not working?
    Problem Solver:
  • 5 Answers
Could of spilled something on the keyboard or there are some tiny objects that fell in under the keys that make the keys not respond. If that does not work, please let us know more about the buttons. ie: The button wiggles a lil or the button does not feel like the others when pressed. If you are comfortable with this. Try taking the button from the laptop and inspect whats under it. Also let us know if all the buttons stopped all at once or did it start with one and followed by with the rest that are not working. Thanks for reading and I hope you get the problem fixed =)
Posted on Sep 10, 2009
2005 trailblazer ignition key will not turn
If you had a dead battery, its likely the code in the radio part of the key no longer is synchronised with the car. Only a dealer can fix that I'm afraid, unless there is a guidance (check, changing the keyfob battery for example) in the car's handbook. Good luck.
Note that when it sometimes (very occasionally) doesn't work its usually due to some kind of radio interfererence just at that moment nearby. There are cases reported here in UK where several neighbours at the same time can't use their car because of some localised radio interference problems.
Dec 17, 2013 | Cars & Trucks
2001 Chev Suburban remote start won't start and now with the key there is nothing.
The electronics involved are too sophisticated to diagnose without electronic kit. Call out a mobile car electronics repair company to come and test the car and tell you what is wrong.
Dec 14, 2013 | Remote Start System
My printer say's it's unable to clean, see troubleshooting menu, can anyone help?
1) Press the Menu and Mono Start keys. Next press the key four times to make the machine enter the maintenance mode. 2) Press the key several times to display 8 on the LCD and then press the Set key. Again press the key several times to display 0 and then press the Set key 3) Press the Mono Start key several times until the purge count appears on the LCD. 4) Reset the purge count to zero by using the and Set keys as follows: Press the key several times to display 2 on the LCD and then press the Set key. In the same way, enter 7, 8 and 3. 5) Exit from the maintenance mode by using the and Set keys as follows: Press the key several times to display 9 on the LCD and then press the Set key. Again press the key several times to display 9 and press the Set key.
Jul 27, 2010 | Brother DCP-110C All-In-One InkJet Printer
Nothing works keyboard locked ? please help on-screen keyboard only
Hello Friend, Hold shift down both left and right shift key at the same time (do this for several seconds), it somehow solved the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut.
Hope this Helped you..Thanks for Using FixYa..
May 08, 2010 | Computers & Internet
Just say unable to clean 35. nothing is working
Hi there you can try this not know if it will work for you but it works with some brother printers
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times until the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. Press the stop/exit key to return to the initial stage of the maintenance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Brother MFC 490cw Color Inkjet...
M Light in the dash came on and stays on periodly,
Some cars are sadly weak from the factory. A pot hole can do damage like nothing else as the g forces are those of an accident yet there is nothing obvious that is crashed from the outside. This is going to be a hunt and peck and a hands on repair. I suggest you take this to a qualified Olds mechanic. Ask around - do a local search and you will find a qualified GM mechanic.
As for the ignition - only put one key in the ignition the extra keys weigh down the unit and will ruin them - some quicker than others. So be sure -- only the ignition key on that small key ring spells a longer life.
Jan 28, 2010 | 2002 Oldsmobile Alero
Van took a few tries to start. Then once off nothing worked.
Might be time for a tune up?
Does your car have a anti-theft system that uses a resistor in the key? I have had several instances when I tried to start the my '95 GM auto, runs perfect normally, but nothing. I traced it back to the key. Probably not always put in correctly.
Thanks for your question at FixYa.com
Jan 18, 2010 | 1996 Chevrolet Astro
1997 saturn sl1 ingnition will not crank
Get new key cut at dealer then insert into ign, Use object to tap strait in several times then jiggle key and rock steering wheel at same time.if this does not work will rquire new cylinder and housing.
Jun 09, 2009 | 2002 Saturn Sl
96 accord - turn key, nothing happens. bad ignition switch? help!
Could be.
Also the jiggling thing could be a coincidence. :0)
Tell me this.... when you turn the key, do you hear a CLICK?? If so your starter is probably bad.
:0)
Jan 05, 2009 | 1990 Honda Civic
HP Pavilion dv4000 Notebook Logo
43 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
