Question about GE DBSR453EBWW Electric Dryer
Clothes taking a long time to dry - GE DBSR453EBWW Electric Dryer
  • 115 Answers
Check your vent pipe for clugs there needs to be air flow for cloths to dry faster
Posted on Sep 10, 2009
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
What setting for drying clothes takes the shorties time
make sure your filters and around your drum is clean that is a reason for clothes taking long to dry
Oct 13, 2014 | Dryers
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
AUTO CYCLE TAKES A VERY LONG TIME, HEAT IS OK, GAS DRYER
First thing I would check is the vent. If you have good heat but it is still taking too long, usually it is caused by a vent that is either too long , kinked or clogged. if the dryer is auto dry and not electronic dry then you will need to gauge weather the load needs more or less dry. If it is just taking a long time for the clothes to dry, more than likely the vent. If the clothes are dry before it is done running then it is more than likely a setting issue. Way out of the box .... are your clothes spinning out dry enough in your washer? do they dry in the normal time on timed dry?
Dec 18, 2009 | Dryers
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
It takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Jan 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
GE DBSR453EBWW Electric Dryer Logo
55 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
