Question about Dell Dimension 4600 PC Desktop
Shift key locked keyboard out, can't use keys
  • 36 Answers
I found that if you hold down both left and right shift key at the same time (did this for several seconds), it it will solve the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut..hopefully this will help you and other people that have had this problem.
Posted on Sep 10, 2009
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
Keyboard keys
uh, for real?
usually there are 2... left below "caps lock" and right below "enter". to use them hold the shift key while pressing the key you want to uh... shift.
Nov 14, 2013 | Computers & Internet
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
How do i make a question mark on my keyboard
? Shift then hit the question mark key, which is next to the shift key on the right hand side of your keyboard
Oct 08, 2010 | Gateway 2520915 Keyboard
My shift key is not working properly in my Keyboarding online class. It gives me an error everytime I try to key in a capital letter. i have changed keyboards and it still does the same thing.
When you say it gives you an error, do you mean an actual error message, or the lower-case letter?
I have no idea what your experience is, so I'm asking if you know the difference between the Caps Lock key and the Shift key? The Shift key has to be held down while pressing the other key, eg h key to get H.
Pressing the Caps Lock key locks into upper-case, SO YOU GET A LINE LIKE THIS until you press it again.
Apr 08, 2010 | Computers & Internet
When i press the letters numbers come up
Your keyboard has a button which permits you to use some of the letters keys as a numeric keypad. It works like a shift lock key and probably has a light incorporated with it as a shift lock key does. In fact it may be labeled "Num. Lock".
Jan 03, 2010 | Compaq Keyboard
When I hit the 'l' key, the number 3 appears.
press shift + num lock and see if works. you should have a green led under the display. when press SHIFT + NUM LOCK , the green led state should change
Jul 19, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
How do i get the keyboard to type the letters instead of the numbers
hold the fn and shift and num lock keys down - this reverts to normal keyboard
Jun 22, 2009 | Acer NSK8458AN Keyboard
MY KEYBOARD DOES NOT WORK WELL. FOR INSTANCE, I CAN NOT TYPE M WIthout holding the right side shift.
brand new Compaq 620 the keys stopped working. FIrst with 6,7, "_", then some other character keys also stopped working. Please let me know how to fix it.
Jun 20, 2009 | Computers & Internet
I accidently locked my keyboard while holding down the shift key,
it sounds like you have sticky keys on.
this would come on by pressing the shift key 5 times.
press any two keys at the same time and the control panel will come up.
Feb 25, 2009 | Logitech Cordless Desktop EX110
Dell Dimension 4600 PC Desktop Logo
700 people viewed this question
Alun Cox
