Question about Fujitsu Plasmavision PDS-6101 61 in. HDTV Television
Confused on tv hook to Dish Network Box up Fujitsu Model#pds6101w
I don't know what cables are needed and how to hook up my Fujitsu 61" wide screen display. Model # pds6101w-s. I have "Dish Network". So i only have one box. The cable jack in the other room works and is ready to roll but my big screen does not have a cable input that would fit. Its all Rgb and all these cables I don't understand. Here is the user manual. This will tell you what inputs and outputs I have on the t.v. Page E-8. The 61 inch display. HEEEEELLLLP MEEEEEE! :)
http://www.fujitsu-general.co.uk/downloads/Owners%20manuals/Pre-10%20series/PDS5003-04%206101%20Users%20Manual.pdf
    Problem Solver:
  • 17 Answers
Call Dish Network for connection support
Posted on Sep 10, 2009
I'm trying to hook up my Xbox 360 to a Philips flat screen tv but i don't know how with the dish network boxs
What does the Dish Network box have to do with anything? Just plug the HDMI cable into an empty port and change your input settings. Done.
Jun 05, 2014 | Televison & Video
Hooking up a Coby tv 32" to dish network but it says no signal
"No signal" usually means you are on the wrong input. Look at the back of the TV to determine what plugs were used to hook up the Dish box, it will be labeled nearby (like Video 1, Component 1 or HDMI1). Now find the "Source" or "Input" button on the TV remote (it can also be found on the TV) and set it to the input the Dish box is plugged into.
If you are using the Coax cable (the kind that screws on), go into the menu of the TV and run a "Channel Search/Scan". This will find the channel the Dish box needs to be set to on the TV.
Let me know if this doesn't work.
Jan 14, 2013 | Televison & Video
What channel does my tv need to be on? and what button do i press on my dish network remote to get me to the wii screen
Usually it depends on how you connected to the TV/satellite box- for instance, I have mine set on channel AUX 1 since I have connected my Wii to the TV using the component cables (the red yellow and white cables) to the port AUX 1. If you've hooked it to the Dish box, then it would be whichever accessory you connected is the channel to select in the dish system, but on the channel that your dish is hooked up (it's situational!)
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jun 25, 2011 | Nintendo Wii Console
The picture wont fill the tv screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jul 08, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
Connecting DVD to cable only TV and Modulator box and Dish Networ
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Jan 01, 2009 | GPX D1816 DVD Player
I purchased the hdtv model DP32648 at walmart, I hooked it up, it is on and working , But some stupid guy told me I needed a cable called HDMI, OK So I have it But I have Dish Network, their is no place to...
ya dish network reg box isnt hd ok u need call dish get hdtv box then u can use hdmi cable to get hi end picture ok for now use cox cable like u do to u can upgrade dish hd sumday k
Oct 15, 2008 | Televison & Video
Wide screen
For example:
The name of the button on the remote is called format.
Hope this helps.
Jan 18, 2008 | RCA F27650 27" TV
Words at bottom of screen
For example:
Hope this helps.
Nov 11, 2007 | Apex Digital AT2408 24" TV
Fujitsu Plasmavision PDS-6101 61 in. HDTV Television Logo
181 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
