Question about Lands Phones
My phone doesn't ring! It will vibrate and key beeps but no ringer! Have tried Master Reset, reload phone from computer, but no success.
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
  • 149 Answers
SOURCE: when a call comes in the ringer doesn"t ring
you need to have the phone programmed to ring. ldtsnj.com can help
Posted on Jan 02, 2009
MNfisherman
  • 11896 Answers
SOURCE: ringer is turned ,i need to know how to turn it on
here is a download of your manual:
[PDF] KX-TG2343File Format: PDF/Adobe Acrobat - View as HTML
KX-TG2343. Pulse-or-tone dialing capability. The unit is Caller ID compatible. ...... Please use only a Panasonic KX-TCA60, KX-TCA86, KX-TCA88, ..... in accordance with the instructions and limitations specified in this manual. WARNING: ...
service.us.panasonic.com/OPERMANPDF/KXTG2343.PDF
Posted on May 23, 2009
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
Posted on Dec 18, 2009
  • 84 Answers
SOURCE: Ringer does not ring on one phone
Well it depends on the model, Most of them you can adjust the ringer volume by pressing the volume up key while the handset is onhook (not in use)
Posted on Jun 22, 2010
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Pebble ringer inop
Does it have a speakerphone function, does that work? It would seem that the second speaker is malfunctioning. There is usually seperate speakers for the earpeice and for the rigner/speakerphone. You could open the phone and make sure the speaker is sitting correctly, it could have rotated off it's contacts. But you may have to replace the speaker, possible found on eBay.
Mar 20, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Will not ring only vibrate
when you set the ringer to ring only will it ring?
on the side of your iphone there is a switch above the volume switch that is a ringer/vibrate switch
switch it and test
Jun 05, 2009 | Apple iPhone Smartphone
Cannot get Ringtones!
Go to settings, - Ring Styles, - select style - change it to loud, go to detail of loud and select ring volume and increase it to 7.
Jan 09, 2009 | Motorola Mobility RAZR V3
I265 model
Go to your ringers menu, find the beep tone, (belive its ringer 10, while phone is the ringer is highlighted, press menu, then assign ringer as call alert. Hope this is what you're talking about. If you meant that it's not beeping when somebody presses the button to call you without alerting you, then you go to menu, settings, DC/GC options, and set "alert type" to ring. NOT vibrate or silent.
Dec 28, 2008 | Motorola Radio Communications
I have a new LG200C cell phone that has been activated with TRACFONE. Problem: when dialing the LG200C from another phone, the the ringer is completely silent, even though I have put all volume settings on...
try pressing the * key for about 2 seconds (until it vibrates or beeps) that toggles between the normal ring settings and "manner mode" which is vibrate
then check menu - settings - sounds - volume
select Master volume and make sure it is not on silent
Sep 28, 2008 | LG Cell Phones
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Mar 03, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
163 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
