Help! My Samsung Washer wont start. It makes a beep sound & shows 1E.
  • Washing Mach... Master
  • 8,220 Answers
Water Level Sensor Trouble.
(When the input signal from the water level sensor is out of
range, the unit will send out beeping sounds and halts the
cycle.
Posted on Sep 10, 2009
My Samsung Washer has a code of 1E which means maybe the water level. My problem is that it want turn off. Even when I push the stop button. The door is locked and it keeps beeping and flashing
1e is usually a pressure sensor error. To open the door you will need to switch off the appliance at the wall then after about 2 minutes the door should unlock. You could try the appliance again as it may just be a glitch but you will probably need the pressure sensor.
Good luck.
Dec 17, 2015 | Samsung Washing Machines
We keep getting an error message E1. We have an LG 2120 model
The E1 or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Dec 13, 2014 | LG Dishwashers
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
My Samsung WA75B9 Washing machine give an error of 1E if we try to start it how can we dignose this problem?
Disconnect the power for some time and if the machine shows the same errror it indicates a faulty application on the board.
Please make sure that the top lid switch is closing, check the lid switch mounted at the hinges to activate the main controller. check the wires to the switch.
secondly try to disconnect the output lines to the main motor and the inlet valve. if the fault changes then one of these has failed and needs a change.
Otherwise the main program controller is a suspect.
Mar 25, 2011 | Samsung SW62ASP Top Load Washer
I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
