Question about ASUS P4C800 Deluxe Motherboard
Wires they connect two 2 pins on motherboard
Wires they connect 2 pins on motherboard names like RESET SW/ PWR sw can i see legend for placement
    Scholar:
  • 102 Answers
Do you have the manual of the motherboard, please mention the type, make, model, manufacturer of motherboard please this way we can help you out. Also please try to mention your question clearly.
Thanks
Posted on Dec 10, 2007
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
Looking for motherboard diagram for model of GA-81945GMH-RH. I got problem to connect "power SW" and " reset SW ". I appreciate your help.
You can download the whole manual for this board from Gigabyte here. Here is the front panel connector page from the manual:
Hope this helps. Thanks for using Fixya!
Sep 30, 2010 | Intel Motherboard
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Nov 25, 2009 | E-Machines eMachines Desktop PC
Unknown Pin Layout on Motherboard
Here is the pinout. Note key pin 2 missing.
1 2
reset+ O X key
reset- O (gnd) O pwr sw +
pwr led+ O O pwr sw -
pwr led- O (gnd) O hdd led+
-- O O hdd led-
| O O --
| O (gnd) (gnd) O |
n/c -| O O |- n/c
| O O |
-- O (+5v) O --
19 20
Sep 10, 2009 | AOpen EZ65 (ez65white) Barebone
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Does anyone know the pin layout for the front panel connector for a EX65-II? (i.e. the UX4SG-1394-II motherboard)
Here is pinout. Pin2 key is missing pin
1 reset+
3 reset- (gnd)
5 pwr led+
7 pwr led- (gnd)
9 n/c
11 n/c
13 n/c (gnd)
15 n/c
17 n/c
19 n/c
2 key (missing pin)
4 pwr sw +
6 pwr sw -
8 hdd led+
10 hdd led-
12 n/c
14 n/c (gnd)
16 n/c
18 n/c
20 n/c (+5v)
n/c = no connection
Aug 03, 2009 | AOpen EZ65 (ez65white) Barebone
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
How to connect a power in motherboard?
Hi zarathoustra, still have your manual? Go to page 25.
As shown here.
26b4ba3.jpg Little fuzzy.
Need your manual, click this link.
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000010
Suggest you save the link.
Good Day!
Mike
Apr 03, 2008 | Foxconn 865A01-PE-6EKRS Motherboard
ASUS P4C800 Deluxe Motherboard Logo
83 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
