Question about Sanyo Televison & Video
I have an older sanyo tv with no menu button. I cant get it to scan for channels
  • xtremecoacht Sep 10, 2009
    Thanks, I thought of getting new remote.
    I have a universal remote programed to the tv but the menu doesnt come up. The power, volume, channel all work but not the menu.
    As for the cable box, it wouldnt benefit me to get hd channels on this tv
    Scholar:
  • 85 Answers
Your options are:
1. buy a replacement multi-remote with a menu button on it and program it for your tv (the 4inone remotes are great for this task)
2. hook up a new digital tuner/converter and tune through it with its remote.
3. find another remote for your tv on ebay.
my personal choice would be #2 as that way you also get hd channels.
as well as a remote.
Posted on Sep 10, 2009
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
How can i program my remote control to operate my TV?
You will need to get a programmable remote. The one you have will not work.
Jan 26, 2014 | Televison & Video
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
Manual needed for Sanyo CP29ST3 - I need to tune in TV channels! I lost the manual!
Sanyo has two parts distributors in the U.S. Both are listed below. You'll need to contact the one closest to you and inquire about purchasing a replacement manual. In the meantime, if you're just trying to program the channels into your TV, you need to bring up the TV's menu and select the screen that has the channel or setup options. All TV menus follow the same general format: you should see icons or words going across the top of the screen or down the left side indicating the different menus that are available. On some older TVs you have to press the menu button more than once to cycle through the different menus. Each menu has different options such as picture options (brightness, color, tint, etc) audio options, setup options, and channel options. Use the arrow keys on the TV remote to manipulate what you see once the menu is on the screen. Once you find the channel options, you need to perform what's called a channel scan. On the screen it may say auto scan, auto program, or channel scan. Once you start the scan, you're done. The TV will scan for all available channels and the menu will disappear once it's finshed.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 22, 2009 | Televison & Video
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Televison & Video Logo
1,286 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
