Question about Garden
Ford 770A loader hydraulics lift cylinder shaft won't move.
I have a Ford 770A loader on a 1910 tractor, with leaks at the seals on the lift cylinders. I bought rebuild kits and set to work using the owner's manual to disassemble the cylinders. First I rotated the cylinder head to thread out the wire ring. Next I was supposed to push the cylinder shaft all the way in and rotate it but I was unable to budge it. I disconnected the hydraulic hoses to prevent any pressure on the cylinder but it still doesn't move at all. Any ideas? Thanks.
  • 3,051 Answers
Hello there:
when you dissconnected the hoses did you turn the cylinder upside down and let it drain cause some hydraulic lift assybelies have a small chamber in the head of them that retain fluid and with out removing the fluid it will do a hydraulic lock and wont be able to move untill you losen the bleeder screw if it has one ok please let me know how this goes for you
Posted on Sep 10, 2009
  • Anonymous Jul 12, 2017
    Your. Piston on the bottom of the rod may have cam appart,you will need a new cylinder
1640A Kubota tractor front end loader or bush hog will not lift
I would say you have air in the hydraulic system or you are low on Hydraulic fluid, I am not sure of the procedure on this make to bleed the air out but a dealer may help you if you ask nice.
Sep 22, 2016 | Cars & Trucks
Anyone have auxiliary hydraulics layout particularly where/how its plumbed into control valve
PDF]2013 Skid Steer Loader Parts - Tractorpartsasap.net - All ...
www.tractorpartsasap.net/.../2013_Skid-Steer-Loader_Parts-Catalog.pdf
Auxiliary Heaters . ... Hydraulic Lift Cylinder . .... Service Manual - Tells you how to take the skid steer apart, how to fix it, and how to put it back together ... in the serious repairs or restoration, you need the shop service manual; It can give you many ...Bobcat. 520, 530, 533. 122571. $48.00. Bobcat. 500, 600, 610. 122521.Missing: layout ‎plumbed ‎into
[PDF]PARTS REFERENCE GUIDE - Service Motor Company
servicemotor.com/catalogs/PM-8490.pdf
HITCH PARTS. 125. HYDRAULIC PARTS ... Find the same heavy-duty quality builtinto Case IH batteries for your truck ... lawn and garden tractor, Case IH has the ... Whether it's off-road, lawn and garden, automotive, or marine application, look ...... 12 Gauge. Aux. Lead, 3/8" Eye with B- Splice 12". ZQC708101. 4 Gauge.Missing: layout ‎plumbed ‎1977 ‎clark ‎520
Massey Ferguson Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages9/
What hydraulic fluid is needed for a Massey Ferguson 390 · MF135 Selling ...... Hydraulics quit working after installing Aux Hydraulic control valve. MF 135 lift
Case Farm Tractor Parts and Manuals - Yesterday's Tractors
Dec 12, 2015 | Garden
My hydraulic lift for my 149 cub cadet will not lift when the snow plow is attached.
Try checking the fluid, it may be low. Or the seals in the cylinders may be leaking and bypassing so you can't build up pressure.
Jan 31, 2015 | Cub Cadet Garden
Husqvarna riding has a puddle of oil under deck I don't see we're it's leaking help
it may be the main shaft seal. I will recommend washing it then try to look for it.
May 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Iv'e got a h120 john deere loader the bucket quit lifting it tilts etc.bad cylinders or what?
check the control valve for the lift operation. If it tilts then the hydraulic pump should be ok but if it is not lifting then then the pressure is not getting to the cylinders to push on the rams. Is there enough oil in the reservoir for the operation.
Jun 10, 2013 | John Deere Garden
My rear hydraulics on my 1979 case 1370 tractor
Sounds like you have a hydraulic cylinder bypass problem on the disc
May 09, 2012 | Diesel Case 1370,1470,1570 Tractor Piston...
The hydraulic steel line on my 2010C bucket loader broke and I dumped a good amount of fluid before shutting everything off. Replaced line and filled tank up, everything worked fine for about 1/2 hour,...
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Sep 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Ford 770 loader front cylinder leaks fluid when operated forward or back. repair process for changing seal
61506-fd.jpg Ford Lift Cover Repair Kit (770)
$10.00
Ford Lift Cover Repair Kit. Fits 500 thur 4000 . Repalces: 3B5564
depending on year of your tractor it takes a rebuild kit, assuming your cylinder and ram are in good shape and free of rust, nicks and scratches, if the ram is damaged a new seal kit will be shortlived, its pretty straing forward repair, the only thing you may need is an adjustable spanner wrench set to remove the endcaps hope this steers you in the right direction
Nov 22, 2009 | Ford Garden
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
System creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
737 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
