Air Purifiers
Problem for Air Purifiers
Generic problem for all Air Purifiers
Using a room that is sealed 20 feet wid...
By trading799 on Sep 10, 2009
using a room that is sealed 20 feet widw by 62 feet long by 10 feet high..how many cubic fet of space is there and If you wanted to change the air in the room ...every 30 minutes how many CFM would be required to do this, I would probably need a fan what size ..??
Solution #1
posted on Sep 10, 2009
Not Rated)
midhungbabu
Rank: Wiz
Rating: 74%, 33 votes
it through a mechanic
Was this helpful?
Yes
No
Popular Solutions for Air Purifiers
Questions and Unsolved Problems for Air Purifiers
Answer
Air cleaner shuts down after 3 to 4 minutes of run time. When I try to restart, it will shut down... (More)
Answer
I have three but now only one 1 can feel any air movement.The other two the lights are on but I do... (More)
Answer
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the... (More)
Answer
I have the Ionic Breeze Hybrid GP from Sharper Image. It has an "arching" problem in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Purifiers:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2528
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
