Question about Sanyo DP32746 32 in. LCD Television
Want come on
Turn the tv on with the remote and about 10 sec it cut off automatic or if I turn it on manual it does the same. I do not get no picute and I only had the tv about six month and have had it on no more then 2o times or less. It was a Display TV when I purchase it.
  • yasmeen ze Feb 11, 2008
    my tv is more than one year old not power coming in we are trying but not
  • Anonymous Mar 05, 2008
    Had Same model for over a year. Two weeks ago stopped turning on,
  • 52 Answers
Hey guys, this problem is not simple as it seem. time for the workshop. when it shuts down after turning on for few seconds indicate that there is a fault in the circuitry. Thereby shutting it off to protect from further damage. Could be any of the PCB, CCFL ballast or even the power supply itself.
Good Luck.
Posted on Apr 29, 2008
  • teresasok
    teresasok May 25, 2012
    so is it worth taking in and having someone look at it, or just tossing it? My tv is about 3 years old...
Hello, I have the Samsung ln40c550 and I have a terrible problem with the speakers hissing. I have tried different connections, and it seems like that is fixing it but it doesnt.
press exite button on remote for 10 sec until message appears select ok tv will turn off turn on tv after 10 sec plug and play seup will appear you must select home use not store demo
Mar 09, 2011 | Samsung LN40C550 TV
'no signal input'
D-Sub is usually used for input from a computer, make sure the TV's input source is set to Analogue or Digital (or DTV) as it seems to be set to accept input from a computer, if you do not have a computer connected, then this is why it is complaining of no signal. It will not automatically defer to normal TV without being told to do so, have a look in the manual, or guess around the remote control to change the source of the signal.
Sep 14, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Tv Turns on for 3 sec.then turns off Remote RM-Y914I know it's the remotecontrol
remove the batteries from remote and try turning the tv on manually and see if it still does it. if it does then your tv probably has a bad part in it and your tv is turning off in fear of overheating, must be looked at with a local repair shop.
May 11, 2010 | Sony RM-V310 Remote Control
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
Blue light
2)wait 10 sec
4)wait 30 sec
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
My magnavox model mwc20t6 keeps turning off after 10 to 20 secs
tv was working fine however when we moved it to another room it will not power on at all even using different plug ins
Nov 22, 2008 | Philips Magnavox 20MC4304 20 in....
Magnavox tv
the automatic code is actived.
Nov 09, 2008 | Philips Magnavox 42MF521D/37 Television
Reprogram remote
xl-7 programming instructions first you need to stuff your head up under the dash and locate your module drivers side upper corner under dash does it say programmable transmitter (the first models had no programable modules) if it says that then......
1 confirm all doors are shut and key is out of ignition
2 open drivers door insert key and turn to on within 10 sec
3 turn ignition switch to off in 10 sec
4 push and release drivers door switch 3 times in 20 sec
5 turn ign. switch to on in 10 sec
6 turn ign. switch to off in 10 sec
7 press and hold lock and unlock button on transmitter for 5 sec within 20 sec of step 6 alldoors will lock/unlockto confirm correct process
8 press lock unlock buttons on second remote within 5 sec after step 7 once again all doors will lock/unlock to confirm
9 to add another remote up to a max of four repeat steps 1 through 8 this was taken directly out of an owners manual supplement that comes with a new keyless entry kit (part number for a xl-7 or grand vitara can't remember which one it goes to but it works on either one is 84900-67810) which you would have to purchase if yours is not programable these instructions are the same for vitara, grand vitara, xl-7 and the esteem hope this helps
Jul 05, 2008 | 2002 Suzuki Grand Vitara
Sanyo DP32746 32 in. LCD Television Logo
137 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
