Question about NetGear RangeMax NEXT WNR834B Wireless Router
How do you connect a netgear router from dsl to cable
  • NetGear Master
  • 32,281 Answers
The DSL modem will have a LAN port (RJ45), plug a LAN cable in this port and connect the other end to the Netgear router's WAN port.
Posted on Sep 10, 2009
What is dsl modem?
Yes it can. The DSL modem is hooked to the phone line or cable and a network cable comes out of it. You hook that cable to the WAN port on the rout
Aug 19, 2014 | NetGear N600 Wireless Dual Band Gigabit...
Why i have to reset the dsl to get the internet to work on my netgear router
Changing NetGear FR328S DSL/Cable ProSafe FireWall Router through DSL in order to Roadrunner Cable television as well as cannot obtain link with web. For safety to own a Quality Security Equipment.
Jun 16, 2011 | NetGear WNR3500L Router
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
Can i use a wireless cable modem gateway (netgear) to make my current dsl modem connection wireless.
If your DSL-modem has one Ethernet port, then use an Ethernet cable to connect from that port to the WAN port on your NetGear router. Then, the router will provide both "wired" and "wireless" connections to your computers & devices.
Feb 13, 2011 | Computers & Internet
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    How to connect ruoter to internet
    If you are connecting to either broadband cable or dsl you pretty much have the same steps. First hook up the modem (dsl or cable) with its own power cable and its own internet connection coming in (dsl will be a usually green phone cable)(cable will be a coaxial line that the cable guy already hooked up). Next get the netgear router and plug in its power cable somewhere near the modem, then plug in a preferably crossover ethernet cable to the uplink connection on the back of the netgear, should be on the same side as where the power cable went in. (and yes you can probably use a straight ethernet cable as well) Plug the other end of the ethernet cable into the only location it will go on the modem, both boxes should already be setup for use, if for any reason they do not work just pull the power on them both at the same time and wait a minute or two and replug them back in for power resets.
    Oct 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
    Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
    Connect the lan cable from the dsl modem into the first port on your netgear router ..
    make sure your dsl modem is on PPPoE mode so that it autoconnects..
    Now just connect to your wireless router via your pc interface..
    *Do add a network key to your wireless network to avoid unwanted access
    Jan 19, 2009 | NetGear WGR614 Wireless Router
    Netgear range max keeps dropping signal
    Is it cable or DSL? Cable should be fine but DSL gets slower everytime a second or third connection is added.
    Jan 04, 2009 | NetGear RangeMax WPN824 Wireless Router...
    Hook up
    Hi Cheryl,
    From your cable/dsl modem please take the cable that comes out of it that looks slightly larger than a phone cable and plug it into a port on your NetGear Wireless Router that is labeled either Internet or WAN. After that is done, unplug the power to both your cable/dsl modem and your wireless router. Plug the power back into the cable/dsl modem and wait about 30 seconds then do the same with the wireless router.
    Next on your computer, there should be a wireless icon by your clock near the bottom right corner of the screen. If you double on it, you will see a list of connections, yours will say Netgear and should have a good signal strength. Double on it and give it about 10 seconds to connect. Voila, you should be on the Internet.
    Please let me know if this solves your problem.
    Thanks,
    Adam
    Nov 28, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
    NetGear RangeMax  NEXT WNR834B Wireless Router Logo
    78 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
