Canonical Ltd. Ubuntu
Problem for Canonical Ltd. Ubuntu
Installing ubuntu on Raid 0
By bagosm on Sep 10, 2009
I have a computer set up with only a software raid 0 set up (2 hard disks). I already have made partitions for ext3 and swap. But how can I install ubuntu on my system now?
When I install through ubuntu alternate install disk (which detects my hard disks fine) when install finishes I cant load ubuntu because it complains about not being able to mount / or something like that..
Comments:
Sep 11, 2009
- I did it all manually, also I set the / at the correct partition. I cannot switch the hard drives around because they are on a RAID 0 set up, which mean I will lose all data! Boot seems to go fine as far as ubuntu go, and / point is set up properly, but it just halts when it tries to mount devices! I hope the problem is clearer now!
Sep 30, 2009
- I already have a windows partition but problem is not grub getting confused. As mentioned in the extra comments system halts when it tries to mount devices (not an I/O error)
Solution #1
posted on Sep 10, 2009
Somewhat Helpful)
erictao20070
Rank: Master
Rating: 85%, 13 votes
Ok I have Duo booted ubuntu a couple of times now. When you were partitioning did you use the automatic or he manual? Since you have two hard disks, I will assume you use a desktop and you know how to take it apart. So, if you did automatics the bestt I can tell you is to swith your hard drives around physically and if that fails try switching g the boot menu order. If you used manual partitioning then when you were creating the ext3 partition you did not type / in the text box labeled Moint Point (that's the best I can help you) I hope this has fixed your problem. GO UBUNTU
Was this helpful?
Yes
No
Solution #2
posted on Sep 30, 2009
Not Helpful)
drubuntu
Rank: Apprentice
Rating: 40%, 1 votes
I have yet to try RAID, but i want to. Best idea I've heard was from a guy that set up the first hard drive with a small /boot partition in addition to the swap and ext3 ones... I guess that way, GRUB didn't get confused.
Comments:
Sep 30, 2009
- Oh okay so mounting, not booting. Perhaps a Volume Label problem? This sounds similar: https://answers.launchpad.net/ubuntu/+source/dmraid/+question/46595
Was this helpful?
Yes
No
Popular Solutions for Canonical Ltd. Ubuntu
Questions and Unsolved Problems for Canonical Ltd. Ubuntu
Do you recommend Canonical Ltd. Ubuntu?
Answer
Answer
Upgraded from 9.04 to 9.10. After upgrade system failed to recognize the Blitzz wireless adapter or... (More)
Answer
Music looks to be playing but no sound, Volume is up and is not on mute.?????OPS is Ubuntu on IBM... (More)
Answer
hi am having same audio problem in CQ40-144TU. Please let me know the solution asap.... (More)
Answer
hello i am looking to setup raid 0 with the alternative install cd for ubuntu 8.10 i have foudn... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canonical Ltd. Ubuntu:
Top Operating System Experts
Rank: Guru Guru
Solutions: 1377
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Operating System Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
