Question about JVC HD-52G786 52" Rear Projection HDTV
JVC tv model HD56G786
I accidentally hit the DIGITAL SETUP in the menu on my television, and now I do not know how to go back. It says WEAK SIGNAL and I can't even change the channel. I normally have it on channel 60, and with my dish network remote, I turn on my at&t homezone. Now I can't even put it on channel 60. Please help!
  • 1 more comment
  • anthony woodard Aug 13, 2008
    I have a jvc hd 52g456 and it is also stuck in digital. I have went to the main setup and tried to go the the scan mode. But when I do this it will sat No Program. I can't even connect a dvd player up to it with out it say weak signal. Please tell me what I'm doing wrong
    MALCOLM HOUGH Jul 08, 2014
    you are on the wrong input setting on the remote or the set,use menu to find inputs stroll untill you line up with the correct one ,,it sounds like you use a cable box that is hooked up to tv bt HDMI
    with my cable box i have to plug intio HDMI1 or i get nothing ,a blank screen ,the input for weeak signal is telling me your on the wrong input,change it with or without the remote ,go to input and not tv,that wont work either even though it is your tv your running,you need to get in line with whatever device you have plugged into tv,like video 1,2,3,or hdmi input 1 or 2,i use 1 for the cable box ,and 2 for the computer hdmi input on the back of the tv,so look at what plugin you are in then with remote or without set the input to either satyelite tv ,or input 1 hdmi,or whatever and all of a sudden the picture will be there and all the channels from your cable box will play on your tv .i found this all out the hard way so i know im right ,i did not even have the right remote for my jvc,but if you go to remote codes on the internet and enter the product name you can get the codes,good lick my friend ,happy couch surfing!
This isn't solution
Posted on Sep 12, 2008
Posted on Aug 14, 2008
It's easy, you just have to go back into the menu setup for the auto channel/tuner setup and rescan for channels. I'd noticed this as well when playing around with the tv when I'd bought it and it had done the same to me.
Posted on Jun 18, 2008
    you can scan all day but if your on dvd for input no channels will show up.
LT-46151 mitsubishi tv, Green light flashes, no picture, back light is on, screen is blue.
If you have any later digital camera or phone with a compatible connector and cable, try connecting this first.
The set may be looking at the wrong input for signal.
Using your remote, check the setup menu to ensure that your source (cable, receiver, etc.) hasn't been accidentally changed.
Often, a blue screen means 'no signal.'
Jun 04, 2015 | Mitsubishi Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
Jvc hd56g786 channels stuck on digital cant get them changed to analog
Using the television's remote control, enter the user's menu. Search for video input and change from cable to antenna. If still experiencing difficulty, visit the JVC website and download the owner's manual to learn the procedure of changing the video input type and deactivate the television's digital decoder.
Dec 22, 2013 | JVC Televison & Video
My jvc lcd does not work with my local air tv, i get weak signals
Ur tv is getting a free air DTV right?Not Cable tv,Satalite or Telicom compannies services?Yes,than.Get a better antana like a roof antana or Digital inside antana to get better stronger and longer ranges to recieve the signal.Go to ur tv Menu.Goto setup Ch. Pick AIR rescan all the free DTV signal again,u should get all channel and a strong signal.
Jul 29, 2010 | JVC LT-32E478 TV
Viewsonic N3250W- turns on, the screen flickers on then its black
This could be a problem with the tv's memory. Try resetting the TV. Unplug the unit for a few seconds (10-60). Then restore the TV to the factory default settings. Viewsonic has changed it's menus at intervals so you may have to check your manual. It may be Menu > Setup > Memory Recall or Menu > Options > Restore Default (or something slightly different). From there, click enter, use the right or left arrow to select YES, hit enter. Leave the menu system (Menu twice). Then hit Menu > Channels and rescan all channels.
An alternative cause of the problem may be a weak signal - check that your antenna is pointing right at the station and is the correct type to get the signal at the distance you are from the station. (Usually a weak signal would also have the audio breaking up but weird things can happen.)
I hope this helps.
(who recently had a channel pair that started out with flickering signal issues and then had one channel lose video and the other audio. The memory reset and rescan resolved the problem.)
Apr 24, 2010 | ViewSonic N3250W Television
Sylvania MTS/SAP TV. I don't have a remote I accidentally hit the ''menu'' button on the front. Now I can't get the TV to show anything but static -- like there is no signal coming in from receiver...
I accidentally hit the ''menu'' button on the front. Now I can't get the TV to show anything but static -- like there is no signal coming in from receiver (either through input jacks on front or on rear. Menu gives various options, but none of them gets me back to being able to see the picture.
Apr 07, 2010 | Sylvania SRT2232S 32" TV
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
If the Mirror broke while the TV was sitting upright, the pieces of glass got down inside the light engine and the cooling fans. I don't think you took the light engine apart to clean out all of the glass so the main cooling fan is probably not running and causing the warning. There is no sensor for the mirror. Did you remove the chassis to clean the glass? You cna remove it again and try powering it up out of the cabinet. There are four fans that need to be running. If the light engine is filled with glass the fan at the bottom of the air exhaust will not turn.
I am fairly certain that since the TV was discarded there is more wrong with it than a broken mirror.
Jan 22, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
343 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
