Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
Ice maker not getting water dispense on door is fine
  • 725 Answers
You need a new water valve. Call us with the model number and we will be sure to get the correct valve out you asap. This should do it for you. We hope to hear from you real soon.
Posted on Sep 10, 2009
  • 135 Answers
Tube going into the ice maker may be froze. Heat with hair dryer.
4 Suggested Answers
duby1990
  • 367 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
SOURCE: Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
Ge gss22 where is the ice maker supply valve
Pull the refrigerator out and follow the water line to the back. It will go to a double valve solenoid. One half is for your water dispenser, the other for the ice maker. It is possible that this solenoid has failed. You can order the part online and replace it pretty cheaply. Just remember to turn off the water supply (usually under the sink) and unplug the refrigerator before hand and have a towel ready to catch water that will drain from the lines.
To order the new part get the full model number of your refrigerator and go to the GE website and look up their replacement parts page. You should be able to search for that model and all of its related replacement parts there.
Mar 08, 2012 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
No ice being made. The water is not eing supplied to the ice tray. The water dispenser in the door is working fine.
Well since water is making it to your door the line itself is functioning. You might want to check and see if the fill tube to the ice maker is frozen. Also try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it does then the ice maker is at fault.
Mar 19, 2011 | Refrigerators
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Refrigerators Logo
89 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
