Question about Polaroid FLM-3732 Television
Polaroid flm2011 hit by lighting won't turn on
Hit by lighting, power board is out.Fuse was blown and when replaced it blew when pluged in instantly. how can I rebuid it or can I?What parts need to be replaced?
Replace the power board. Look on line.
Posted on Nov 28, 2011
  • coxrobert1 Nov 28, 2011
    Try shop Jimmy's. Com
    WWW.shopjimmy.com this is the website.
I was wondering if you figured out what was wrong with your tv. I have the same problem.
Posted on Nov 27, 2011
How do I know if it is a board or power supply issue?
Without proper test equipment it is hit and miss. I can say that it is most likely the power supply. The only possible way you might be able to check is to unhook the other boards and try again. If it does blow out the fuse then it is the power board. BUT the unit might not power up at all if you unhook the other boards, especially the control board.
Feb 05, 2016 | Emerson 22" Class LED-LCD 720p 60Hz HDTV,...
1993 Dodge B250 Ram Van (Conversion) -- I have no rear running lights. The brake lights, turn signal lights and hazards all work fine. While driving through rain, I hit a big puddle. Some time later...
something in the wire setup has gottn wet and caused it to short out . i would recomend ordering a new wiring harness for the engine compartment. and when re connection everything use di eletcritc grease in them so they will not do it again.
Oct 07, 2013 | Cars & Trucks
Power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
Nov 03, 2012 | 2002 Dodge Neon
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Oct 27, 2012 | Polaroid LCD-1700 17 in. Television
No power on 2002 Mitsubishi VS-60609
You have a short in the power supply or high voltage. You will need a sevice tech to deal with that problem. Make sure to get an est before repair
Jun 19, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Blinking LED light and set will not turn on.
blown capacitors on the inverter/vga board replace them and you should be good.
Apr 27, 2008 | Polaroid FLM-3732 Television
Ilp iwt3206 32" sdtv
Next best guess is the larger filter capacitors in the power supply are bad and shorted out, you can check with an ohm meter across capacitor leads (with power unplugged)
Apr 21, 2008 | iLO 3200 32 in. LCD Television
Polaroid flm 3201 wont turn on
If you have no power light at all on the front of your tv. Check the fuse by the power coard.
If you have a red light only and have the dark power board with black heat sinks. check the fuse in the center of the power board.
if the light turns blue when you hit the power button but no picture and have the dark power board replace the 2- 1000 mfd 10 volts caps with 2- 1000 mfd 16 volt caps at 105 deg.
need more help let me know
Nov 24, 2007 | Polaroid FLM-3201 Television
Televison & Video Logo
108 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
