Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need an air filter for poulan 306a
I have gone all over the net and stores trying to find an air filter for my poulon 306a. does anyone know where to find one or a filter that would fit from another saw?? Thanks, Lynn
  • Roberta Smith
    Roberta Smith May 11, 2010
    what country are you in ?
    President:
  • 2,220 Answers
Simple answer is no!
Lou
Posted on Sep 10, 2009
  • dontbother10
    dontbother10 Sep 10, 2009
    Look around your area, find the chainsaw mechanic that has little hair and what is there is gray or white, and has been at it his entire life. Take the saw to him and ask him if he thinks it possible. If yes ask the cost. A new Poulan P4018 (there are better models) can be purchased for about $160.00. That is about 3 hours of the mechanics time. Is it worth the modification?
    You can also try here:
    http://www.arboristsite.com/forumdisplay...
    This is a collection of chainsaw enthusiasts that will give you grief for owning a Poulan but will help none the less.
    There is nothing more we can do!
    Lou
  • dontbother10
    There is a pretty good chance someone at Arboristsite has overcome the filter non-availability problem for your saw.
Fuel lines have deteriorated and need to replace
I just took mine to a local Poulon Repair shop about 16 miles away and they replaced the lines and the grommet and only charged $6. You can find someone in your area through the Poulon website:
http://www.poulan.com/service-locator/
Aug 23, 2013 | Poulan 25cc 2-Cycle Gas Powered String...
Poulon pro 18" smoking
The only way a two stroke can smoke is either it is running far too rich ( possible blocked air filter ) or there is too much or incorrect oil in the fuel, if the oil tank for the chain is sepereted from the crankcase by a gasket, it maybe the gasket leaking and allowing chain oil into the crankcase.
Sep 10, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a model 306A poulan chainsaw will not start. It will fire with starting fluid. I am not sure how to adjust the air fuel mixture screws properly can you help?
I'm guessing that its not the screws. The screws are typically set at 1 1/2 turns out for initial setting. More likely that the carburetor needs a rebuild. The carburetor on a small 2 stroke has a fuel pump within. If it goes bad it wont run. The other thing you can check is the fuel line inside the carburetor. Many times when the fuel line gets old it cracks and the carburetor just pulls in air. Open the fuel tank, dump out the gas and look at the fuel line. Make sure the filter is still attached.
Jan 09, 2011 | Garden
My Poulon blower begins to start but then dies? I tried changing the spark plug with no luck.
The carb probably needs to be rebuilt. There is a very fine screen in the carb that gets clogged up. When it is clogged it actually looks more like a metal plug than a screen. Even with a filter in the fuel tank dirt will make its way to clog this screen.
Apr 25, 2010 | Poulan Pro Gas BlowerVacuum ()
Poulon-Pro leaf blower manual
If you know your model number (i.e EVB160 etc) you can use this link:
http://www.poulanpro.com/node4043.aspx
enter your model number and download it.
If you do not know your model number
click on products same link, then click on blowers (not snow throwers) find your model then go back to the users manual download.
Thanks for using fixya.
Feb 14, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Poulan 306A, chain keeps tighting up during use
Have you checked the oiler? If not oiling what you report is the outcome. You can post back below.
Oiler detail can be found on the "Handlebar & Oil Tank Assembly" page here:
http://www.ordertree.com/modelinfo/PWE/306A-Gas-Chain-Saw/75.306A-Gas-Chain-Saw.1.59.1.html
If I can be of more assistance please reply below. I hope you found this helpful.
Lou
Jan 19, 2010 | Poulan Garden
I would like know where to get a tap and go head for a pp325 poulan
Try your local Poulon dealer. If you dont have one, try Lowes, Home Depot or other hardware store. ...Lee
Sep 06, 2009 | Garden
I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Sep 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Having hard time with new poulon 18" chainsaw starting.
Since you have good spark and good gas the only things left to check are the air filter and the carbeurator. If the air filter is dirty, replace it. While you are at the auto parts store also pick up a can of a gasoline additive called seafoam which will keep your carb. clean. Finally get a can of spray carb. cleaner and put a couple short squirts directly into the air intake which is right there when you remove the air filter.
May 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
212 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
