Question about HTC Touch Cell Phone (Unlocked) - Soft Black
Screen locked up need to know how to reset - HTC Touch Cell Phone (Unlocked) - Soft Black
My lock screen on galaxy 5 won't come on. It goes straight to home screen. Why is it doing that? It was fine 2 days ago. How can I get it back?
Three Reasons Why Screen Lock is Gone
1. Screen Lock has been deactivated (Instructions how to activate are at bottom.)
2. Android Screen Security File may have been deleted, and screen lock option is no longer on your devise.(A Factory Reset will restore original Android files)
3. Malfunction Somewhere in Samsung Phone. (A Factory Reset might work, but not guaranteed)
(How to Factory Reset phone at bottom.)
How to ativate Screen Lock and Security settings
1. Press the apps icon, it usually at the bottom of screen.
2. Find Settings and press that button to open settings menu.
4. Scroll down the menu to Lock Screen and Security, press that to open options menu.
5. The first option at top is Screen Lock Type.Press and Open.
6. You will have 3 lock types to choose from. Swipe Lock, Passcode Lock, Password Lock
(advise, do not forget password, only a hard phone reset, or an apk lockout file will get you back in)
If activating screen lock through settings did not work, or if option is not available, you can try to reset phone to the way it was when you bought it.
There is a couple things you should know.
1. contacts, photos, videos, downloaded apps, games, and everything not on the phone when it was first bought, or when you first got the phone will be erased.
2. You can back up contacts, photos, videos, in settings menu, scroll down to Backup and Reset. Or save to an sd card, and remove sd card before applying reset option
3. If you have an account (google or android email) associated with your phone, you will need email address, (example@any.com) and password to get back in phone after phone resets and turns on.) Dont remember password, Please create a new password now before continuing to reset to manufacture settings.
Reset Phone to Manufacture Settings
1. Remove SD Card, or its saved files will be erased.
2. Open apps, Open Settings Menu, Scroll Down to Backup and Reset.
3. Scroll down to bottom of page to Factory Data Reset.
4. Follow instructions to reset phone.
When your phone comes back on, Swipe Screen Unlock should be active at phone turn on, if screen lock is not showing try again to turn on in security settings.
If still does not work,
I am sorry, Your phone has permanantly malfunctioned. You can try your phone store, or a phone repair shop.
Mar 10, 2017 | Samsung Galaxy Cell Phones
I bought a LG 4GLTE....keeps saying this device was reset. To continue, sign in with a Google account that was previously synced on this device. How can I get past this?
This is an activation lock through Google. Basically, the device was factory reset, and there was a PIN or SWIPE lock screen and a Google account on the device when it was factory reset.
As a layer of protection and to ensure the phone is not stolen, it is looking for you to enter the Google account that the device was ORIGINALLY set up with. If you know the Gmail login, but need to reset the password, you will not be able to login to the phone for 72 hours AFTER the password reset.
If you do not know the login, there is no way to bypass this screen. You would need to get the Gmail account information from the original owner.
If you have more questions concerning this, here is an in-depth explanation of the security lock. Guide What Is Android 5 1 Anti Theft Device Protection Feature And How Do...
Feb 25, 2016 | LG Cell Phones
I have a motorola droidmverison phone i did a factory hard reset. And no2 i cant log in cause i donrt. Have the old email info How do i by pass log in with nold user account
Feb 24, 2016 | Motorola Cell Phones
Forgot pattern lock to LG 306g how do I reset it?
Press and hold the following keys at the same time: Volume Down Key + Power/Lock Key on the back of the phone. Release the Power/Lock Key only when the LG logo is displayed, then immediately press and hold the Power/Lock Key again. Release all keys when the Factory hard reset screen is displayed. http://www.lg.com/us/mobile-phones/VS980/Userguide/075.html
Apr 05, 2014 | Cell Phones
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
How to reset samsung galaxy ace gt-s5830 with screen lock?
i forgot my screen lock and i cannot open my mobile phone and i want to reset just to unenable the screen lock..
Jan 31, 2013 | Samsung Galaxy Ace GT-S5830
My F22 monitor had been appear OSD locked and i don't know how to solve it. Some buddy please help me!!!
important notes
1. what is displayed on the monitor comes from the system unit
2. possible features that could be displayed on the monitor are screen savers or splash screens
3. attempting to log on a computer with a screen saver passcode could lock the system by displaying the word locked requiring unlocking
procedure of unlocking a passcode
1.Once the system locks, would require to reset the password.
2. another function could be displayed on next to the lock icon prompting unlock or reset
3. in the absence of a display of unlocking the password, continue to enter the wrong password and hiting the logon button in a space provided next to the unlock icon prompt
4. severall attempts would prompt for a reset functionality.
5. at which instance would display a password hint of what has been locked.
6. the password hint provided must be guessed correctly to allow a reset functionality.
7. once hint provided allows for reset would prompt the user to create a new password
8. create a password with a hint as a key to reseting any future locked screens.
9. the screen could be operated without a password for an alternative, only made possible during after unlocking the locked screen. instead of creating a new password and hint, choose to disable screen savers altogether.
Dec 06, 2010 | AOC F22 Monitor
Locked ipod nano
you need to restore the ipod
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Good luck.
Apr 04, 2008 | Apple iPod nano
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
49 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
