Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
C-467/06 This is my problem its the inlet water and appears to be control valce? can you help' Water leaking on my hardwood floors.
  • 415 Answers
If the unit is overfilling make sure the float moves up and down freely if the valve try to tighten the connector where the hose/copper pipe hooks up to the valve
Posted on Sep 10, 2009
I have a great model # tpx24srya-bs refrigerator and when the icemaker is on it leaks water from I don't know where. When Ice makers off there's no leak.
There is a solenoid valve and a plastic water hose that connects to the ice maker. Looking at the rear of the unit you can see where the plastic tubing connects from behind the air shield into the solenoid. A second hose connects from the solenoid to the water inlet connection on the wall. The connection to the wall is probably OK because it would leak with the ice maker off if it did,
It is the hose that goes up from the solenoid through a hole at the upper right top that is the most likely culprit.
Look for water coming from a failed hose at or near the solenoid valve connection where the ambient heat is the highest. It is the heat of the hot air that deteriorates the hose. Replace the hose.
After ten years many are known to fail?
"Protect floor before rolling filled refrigerator out from the wall!" The weight will scar the floor from the wheels including hardwood floors!!"
Hope this helps?
Nov 07, 2016 | Refrigerators
Remove mold on hardwood floor
Spray the oak floor with a 50% solution of white vinegar solution mixed with water and let stand for an hour, then clean with hot soapy water. Alternatively clean the floor with a steam mop, as either method will kill the mould on your floor.
May 24, 2014 | Shaw Solid Hardwood Floor 2 1/4" x 3/4"...
I have a Jenn-Air JFC2290v water appears on the floor front right corner, sometimes front left corner as well. I have moved the unit and have not found any water under it. This has been on going for...
I bought the same JFC2290 model and it says "Auto defrost". Mine is only 10 months old and it starts having exactly same problem already. Water leaks and I have to clean my hardwood floor twice a week. I will never own Jen junk again!
Nov 09, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
The unit is on a hardwood floor and there is water damage to the floor. The unit appears to be dry now. Could it have a leak that can't be seen?
The potential for water leaking to the floor is probably still there. Open the door of the unit, look in the back and you will see a white plate; that is the evaporator. When the unit is running, there is a light frost that forms on the front and back surface of the evaporator; sometimes the frost can get a bit thick because of air laden moisture infiltration or the frequency of door opening. That frost eventually will melt and drain from a drain hole right underneath the evaporator. If that drain hole is plugged up, water will eventually leak out from under the door. Keep that hole clean and patent and also check the state of the water collecting pan underneath the the unit. That might solve your water problem.
Jan 21, 2011 | VinoTemp VT-TC32G
Water leaks every 5-7 days from the freezer. I
If your water valve is not closing properly, it will do that. The water valve is not very expensive. If you have ice and water in the door, there are 2 water valves. Replace BOTH! If one is weak, the other is not too far from giving out too.
Jun 01, 2010 | Refrigerators
Water leaking from hot water connection
Try sliding the panel backwards it should slide off.. Hopefully this should do the trick
Apr 26, 2009 | LG WM-2277HW Front Load Washer
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
136 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
