Question about Whirlpool Washing Machines
Our Whirlpool quiet wash II is leaking water onto the floor while doing laundry. It is only a small amount, but obviously there is something wrong. Any suggestions?
  • 1 more comment
  • megan_mickus Sep 10, 2009
    It is draining into the back left side of the washer. I don't know if it is when it is filling or draining.
    The water is sitting on the back left side of the machine. I am not sure if it is there when it is filling or draining.
    Thanks!
  • fixrguy May 11, 2010
    is it over filling in the normal wash cyc or pump has started to leak is the water in the front of unit or the back check the house drain to see it it backs up when the unit is draining
  • 415 Answers
It sound like a hose has sprung a leak or the hose that fills the tub has come out of place sorry it took so long for me to reply fixrguy
Posted on Sep 12, 2009
I have a Whirlpool washer, i put a new water pump on and i put a new drain hose on. And it's still leaking water on the floor what could be wrong.
on this machine common problem is look right under the machine right under the heater you will see its coming from there if its not from there it will have a split in the drum as the plastic is really fin have a good look you can arrowdite normaly will do the trick but make sore all water is gone ok
Oct 18, 2012 | Whirlpool Washing Machines
Water leaks from my Aquasmart 8 kg washing
On most units, the water pump was a "weep" hole on it which tells you pump needs to be changed soon. It tells you the internal seals are starting to fail.
Dec 28, 2009 | Washing Machines
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Top load whirlpool washer model LSQ9544KQO leaking small amount
more likely from a hose........need lid off and a good torch
cheers
Aug 03, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Duet washer, water leaks out onto the floor, when not running.
warter seeping through valve remove power cord. them cut off water at wall remove 3 t20 screws from back of top panel slide panel toward rear to remove. remove hoses and electrical connections from valve remove 1 t15 srcew from back of rear panel to remove valve replace with part # 8181694 for about $50
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II - Whinning and leaking small amount of water
If the water is appearing in the front of the washer, you may have a leak in the drain pump. The link I'm posting below gives step-by-step instructions on how to replace the drain pump.
http://www.fixya.com/support/r397092-replacing_water_pump
If it is not the drain pump, at least this gives you the necessary instruction on how to access the cabinet interior to inspect it properly. A whining noise could be something caught in the pump, or something stuck between the wash tub and outer basket. In order to run the washer with the case removed, you will need to by-pass the lid switch. this accomplished by jumpering the two BLACK wires on the lid switch connector at the timer. CAUTION: Unplug the washer before connecting the jumper wires. Then, plug back in and start the washer. Fill on the lowest setting and look for leaks.
NOTE: The drain pump is not serviceable and must be replaced if leaking.
I hope this helps you. Let me know if you have further questions.
Jun 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer
dsands, if the noise is like a train roaring then it could be the bearing. The fact that you have some water leaking leads me to believe that the tub seal leaked onto the bearing. Now this could be covered under the 5 year warranty, depending on the tech that comes out. Another possiblility is that something is caught in the pump and it is leaking. You would have to open the front panel to get a look. On these Maytags if something gets in that pump like a button etc., they will scream like a raped ape. With out being there my gut feeling tells me the seals leaking and ruined the bearing. Catriver.
Dec 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
