Question about American Standard 4112.016 Cadet Toilet Tank, Spring
My toilet is double flushing. How can this be
My toilet is double flushing. How can this be fixed?
  • 68 Answers
Can you call anybody?
Posted on Sep 10, 2009
NEW SUPPLY ASSEMBLY IS LEAKING
The troubleshooting guides are here
Zurn Flush Valve Troubleshooting Guides
Video help with the unit
Zurn Pressure Assist EcoFlush Technology - YouTube
? 15:09
https://www.youtube.com/watch?v=6LLZETU-HLo
Jun 30, 2015 - Uploaded by Nebula IMS
Handle Assembly Replacement ECO Flush - Duration: 4:18. Robert Huang 12,297 views · 4:18. Toilet won't ...
Eco flush model B8106 - YouTube
? 1:48
https://www.youtube.com/watch?v=mrfpMG772P0
Dec 22, 2017 - Uploaded by Robert Tushaj
Toilet not flushing.
Model B8100 series Ecoflush toilet will not flush HOW TO FIX - YouTube
? 1:25
https://www.youtube.com/watch?v=C-BzFy_nRiE Mar 6, 2017 - Uploaded by Jeannine Menger
Model B8100 series Ecoflush toilet will not flush HOW TO FIX ...
Ecoflush flushing issue - YouTube
? 0:26
https://www.youtube.com/watch?v=oZQ2xT_uUp4 Aug 3, 2013 - Uploaded by Jos? Muanis
This is Gerber toilet with an Ecoflush model B8100 The toilet was not flushing, I made this video trying to ...
May 13, 2018 | Cars & Trucks
Bemis duel flush toilet leaking, how do I fix it?
If the leak is inside the toilet, then you have a defective flush valve or flapper Which ever one is in your model toilet.
Jul 25, 2014 | Bemis Home
What are the most common venting problems for toilets?
What all that means is the sewage pipe going to the street is getting clogged so either snake it with 50 foot snake or go buy so Drain-O (60 ounce bottle costs about $9) and pour 1/5 in toilet and wait 10 minutes then pout 1/5 in Bathroom sink & wait 10 minutes. Keep do that until 60 ounce bottle is empty. Let this stay in pipes for couple hours and your toilet will double flush now its clean with no corrosion, hair, cooking oil, and other debris.
Apr 17, 2014 | Home
Toilet wont flush
Main 3 (or 4) inch drain under the toilet is clogged. Requires removing the toilet and running a "snake" down the pipe. Alternately, you can (carefully) try manually filling the toilet bowl all the way to the top----to apply pressure to the clog....it may push it through.
Mar 04, 2014 | Home
My flushmate toilet got clogged. I have unstopped the clog, but it won't flush. The flushing process works, but the water isn't pushed down the drain.
My flushmate toilet was stopped up after a bm.
Because I could not get to it right away, I let it
sit for several days. Tried calling the Flushmate
800 number. They don\'t work on weekends and
it was Saturday. What to do? Read the info on
the internet but could not find solution. However
first I shut off intake water valve required for any service
performed. Did that. Got a large plastic spoon.
Fashioned a container out of supermarket paper
bag cut in half. Used bottom half and inserted it
inside double Safeway plastic bags. Scooped out
the toilet paper and feces into bag. Found most
of feces had disintegrated in the toilet coloring
water dark brown. That was a good sign. Less
solid matter to flush. Tossed bag into garbage.
Flushed the toilet and it worked perfectly. This
method works for stopped toilet only. If problem
is in the sewer line, you need another method.
Oct 19, 2011 | Sloan M-101526-F42 Flushmate?® Complete...
I have a Carlyle water saver toilet. The one that has two push buttons built into the toilet tank lid. It is a solid 1 piece toilet. My problem is every hour the toilet is flushing by itself. Had a...
Hello. Your lid has two buttons so you can do a half flush or a full flush. A water saving feature. Since the toilet is flushing by itself every hour or so, you must have a leaking flush valve. Replace the valve to solve that problem. Joe
Oct 12, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
I just installed a Kohler Wellworth toilet. Wheni flush the tank only empties about 3 or 4 inches and then shuts off. The water level is at the highest. How do I correct this. Thanks
As long as this toilet is NOT a pressure assist toilet. Then it probably has a water saver flapper that you can replace with a non water saver flapper. This will allow it to flush more. Be advised you may have to adjust the water level after the change to prevent it from double flushing. Hope this helps.
May 21, 2010 | Home
I have a new sterling 1.6gpf toilet can I increase the amount of water in the bowl. Every time or almost everytime, waste sticks to the bowl and I have to brush it loose.
If you raise the water level in the tank it will double flush. I suggest you change out the toilet to a Toto or Kohler class five flush action.
Nov 13, 2009 | Sterling Home
Toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Jan 17, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
American Standard 4112.016 Cadet Toilet Tank, Spring Logo
137 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
