Question about Dryers
Dryer wont start, timer clicks but wont start
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Get new dryer.
repar old dryer same almost same price
get new motor , if motor runs get new belt,
repair wire line or plug .
did you check the house fuse/breaker it blew/ tripped up ZZZZ
Posted on Sep 10, 2009
  • 415 Answers
The thermal fuse is open its the white plastic looking item on the blower housing
4 Suggested Answers
  • 83 Answers
SOURCE: dryer wont start
What clicks?
The timer or a part from inside?
I am thinking either the timer control or door swith has become faulty.
Am I correct in saying that the motor does not start and/or the drum does not spin?
Posted on Sep 16, 2008
  • 2128 Answers
SOURCE: Dryer wont run, lights work, timer clicks
what is the model number?there are a couple of things you can check with the little info you sent,check the door switch,push the paddle in and out ,if it doesn't click it's bad,check to see if the belt broke,on some dryers there is a switch down near the pulley,if the belt brakes the dryer won't run,one more thing if your dryer hasn't had a clean out in a long time or if your clothes have been taking a long time to dry check the thermal fuse located on top of the blower wheel housing,if the lint filter is on top the fuse is in the back,take off the vent line,remove the back panel and check the fuse located to the right and down near the bottom of the duct that the lint filter slides into,if the filter is inside then the fuse is in the front the fuse is on top and to the right of the blower wheel housing,also you should clean out the duct that the filter slides into,blow out the vent line,check outside and make sure the flapper is not blocked with anything and vac out the inside of the dryer where the motor is,you need to do this once a year anyway,if you still need help send the model number and let me know what you find,unplug the dryer to clean it and when working on it and remove one of the wires when using your meter
Posted on Mar 17, 2010
heatman101
  • 43501 Answers
SOURCE: My electic dryer..Roper RES7745PQ0 wont
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 21, 2011
The knob on the right just turns (no clicking) so it does not seem to be selecting a time. now dryer wont start.
Check your timer knob. On these GE dryers I have found a lot of times the knob cracks where the stem of the timer goes in and the resistance of the timer will make ti slip internally rather than turning the knob. If the knob appears to be ok, then I would say you definitely have a bad timer on your hands.
Timer is part number WE4M271 and runs around $100 from marcone's
Knob is
WE1M654 and is around 18$
Good ;uck with this!!
Jul 05, 2010 | GE DBXR463GDWW Gas Dryer
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
Model ler8857eqo wont start has powr timer makes clicking sound when timer is turned off start button clicks back out
you nead the unplug the dryer and pull the dryer away from the wall to get to the back panal.next remove the vent hosefrom the dryer.next remove the back panal and the power cord cover.if you look down and to the left you will see a white plastic thermal fuse.remove the wires from the fuse and check that it is closed.if it is open the replace the fuse and reassemble dryer.
Jan 19, 2010 | Whirlpool LER4634J Electric Dryer
Wont start
Is the motor running but the tub not spinning? You can tell by feeling for air movement out the exhaust after you start it or by listening to the dryer (put your ear against it and listen for a humming sound).
If motor is running your belt is broken and will have to be replaced.
Sep 02, 2009 | Dryers
Dryer wont start
What clicks?
Sep 16, 2008 | Dryers
Dryer wont come on
check the voltage at the outlet for 220
Feb 16, 2008 | Roper REX4634KQ Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
152 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
