Question about Dell Vostro 1500 Notebook
My Dell Vostro 1500 has a problem. AC adapter turned off when I plugged into laptop while battery plugged. It works either battery or AC adapter. Can't Charge battery. Please help!
  • Dell Master
  • 32,281 Answers
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Posted on Sep 10, 2009
Dell vostro 9lock button blinking and no display
Hi sarwankuma5,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Feb 17, 2011 | Dell Vostro 1500 Notebook
My dell vostro 1500 laptop doesn't boot up the battery and ac power source is fine, what happens is that the only light or noise that comes form it is that the caps lock blue light indicator flashes for...
it sounds like your ac adapter has burned out and won't charge anymore. That's very common... that's why they are so cheap on ebay. Either that or your power plug on the motherboard is cracked or loose at the motherboard (2nd most common) and last bad motherboard (don't assume this unless last resort.)
Jan 12, 2011 | Dell Vostro 1500 Notebook
The a lcok is flashing and my vostro 1500 will not start, what can i do>
Hi ekazar,
Hope it helps.
I have a DELL Vostro 1500 laptop, since the last 2 weeks it appeared a message when i turn on my laptop, it says: " The AC power adapter wattage and type cannot be determined. The battery...
Certain models talk to a chip in the adapter, sounds like this one has gone bad. At this point you can live with, buy a new one or pick up a used. This is a fairly popular model and you should be able to locate one from a dead laptop.
Mar 06, 2017 | Dell Vostro 1500 Notebook
Suddenly died with blue screen of death. will not turn on again. when I press power button, it lights up and battery light lights up also. as soon as I take finger off the button, nothing. tried...
No guarantee but you can try this. Remove the battery and unplug the AC adapter. Hold down power button for 30 seconds. Plug in AC adapter but leave battery out. Try to restart computer. If it starts, reinstall battery. It worked on a Gateway I was working on last week. Worth a try.
Aug 27, 2010 | Dell Vostro 1500 Notebook
Dell Vostro 1500 not switching on...
Motherboard is bad that's why the ac adapter light will turn off ,possible short ciruit on the board. you need to have a replacement for it. Call dell tech support for repair.
Jul 21, 2010 | Dell Vostro 1500 Notebook
Dell vostro 1000 laptop power problem.when you plug in the power supply before its plugged into the computer the green lite is onwhen you plug the adapter into the laptop the light goes out and there...
older vostros usually have a broken dc jack right where the power connector plugs in. otherwise try another ac adapter and also try removing and replacing the battery underneath.
Jan 30, 2018 | Dell Vostro 1000 Laptop
Will the power cord for the Dell Inspiron 1501 fit the Vostro 1500?
AC adapter for both systems belong to D-Family 65 W lead-free AC adapter So you can use the Ac adadpter Note :- The Vostro 1500 discrete version requires the 90 W AC adapter. Without it, you will receive an error message indicating the wrong AC adapter type, the CPU speed will downgrade, and the battery will not charge.
Dec 21, 2009 | Dell Inspiron 1501 Notebook
Won't Start No lights flashing does nothing when I hit the power button
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
May 08, 2009 | Dell Vostro 1500 Notebook
The battery is not charging
Normally, one of 3 causes.
  1. Dead Battery
  2. Bad connection of battery interface on Motherboard.
  3. The AC Adapter sensing pin (In the center of the plug) is damaged (If the system cannot sense the AC adapter, the charging circuit is disabled.)
Troubleshooting:
  1. Try a different AC adapter (Any Dell D-Series system adapter is interchangable)
  2. If no difference, then next is replace the battery.  (The battery on a portable is a consumable item, and the battery life is generally 300 to 500 recharge/discharge cycles  around 18 months)
  3. If no change with battery or AC adapter, then the failure is the charging circuit of the motherboard.
Mar 25, 2009 | Dell Vostro 1500 Notebook
Dell Vostro 1500 Notebook Logo
461 people viewed this question
Alun Cox
