Question about Philips GoGear HDD1830 MP3 Player
File system error
When i turn on the mp3 player the words file system error appear on the screen
  • 60 Answers
Push in the tiny reset button on the device. If that doesn't fix it, install the latest firmware from Philips.com
Posted on Sep 19, 2009
Philips gogear 8gb mp3 file system error
m8 that happens to minebut i cant fiqure it out
Oct 22, 2011 | Philips GOGEAR SA6045 MP3 Player
When I switch my Thomson 2GB mp3 player on, the word 'Thomson' appears on the screen and instead of showing the menu, the mp3 player switches off by itself. is my mp3 player corrupted? Darryl
the answer is yes. Your mp3 player is corrupted. It must have gotten virus from the computer you used in download songs to it.
The start-up files of the OS (Operating system) of your player is corrupted.
To fix this, you need to do a firmware update. The previous version will be deleted and a newer one will be installed. By so doing, your player will be back to normal.
Good luck.
Mar 04, 2011 | Thomson Audio Players & Recorders
My ipod is showing file system error
Hi
File system error can appear due to unplugging the MP3 player without disconnecting it. It may have happened due to formatting it with a different file format or due to memory issue with the player. Please reformat your MP3/MP4 player. Connect it to the computer, go to My computer-> right click on the mp3/mp4 player after it is displayed-> select format-> Format it as FAT32 File system. Formatting the MP3/MP4 player will delete all the songs/data from the player. So, backup all data before formatting it. Hope this helps...
Daniel
Sep 18, 2010 | Philips GOGEAR SA6045 MP3 Player
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
Everytime I try to play music on my Nextar MA794-20S the words"File Sytem Error" appear. And now the screen is frozen.
the files you are trying to play are are not in the format supported to your device.
save the files compatible to your device. thanks
Dec 29, 2009 | Nextar MA794-20S Digital Media Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Oli mp3 player
hi!
in your case, there might a system file on your mp3 player that was corrupted, you really have to backup your file, copy all your files from your player to the pc and format your player.
Oct 29, 2008 | iLO (2 GB) MP3 Player
White screen, have to do a soft restart and then words show up
I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
Jul 09, 2008 | Apple iPod MA446LL/A MP3 Player
Owners manual
Hi! Dear I have Owners Manual I can email you Also can you explain me how to open Gigabeat to remove battery and HD Please email me at PATELJITU28@hotmail.com I will attached manual once you provide me your email Thanks Jitu
Sep 01, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
My M512A3 kenwood doesn't work
This error usually occurred when the player is removed unsafely from the computer... Make sure to use the "the safe hardware removal ". In order to fix it, try to format the player with the original CD-ROM? it will fix it. Be aware that it will erase every data on the player. sorry. Good luck.
Dec 08, 2005 | Kenwood M512A3 (512 MB) MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
261 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
