Question about Whirlpool Duet GHW9150P Front Load Washer
What causes f35 code and sud errors
I can take the drain hose and blow back torwards the washer and it will run for about 2 washes
  • 415 Answers
Are you using the HE soap if not and using the brand you used on your old washer you must not use alot of soap or if will fail over and over. example you should not use more than 1/4 cup of soap on a full load of cloths if you see sud through the door reduce is yet more or give to a other family member and get HE soap you error codes will stop and when you remove the cloths the sound of stickyness will be gone
Posted on Sep 10, 2009
Testimonial: "Thanks for the help maybe i'll try another brand of HE soap"
My whirlpool duet front load washer is giving a F21 error code. It will not drain. When I blow into the drain hose on the back of the washer it will start draining. But everytime I run a new cycle it will...
whirlpool duet front load washer this video is on a bosch but it will help you Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Trying to find pump.
Hi - I understand you will like to know where to find pump and check for clogs. Try the following steps below and hope it is helpful:
To completely clear any clogs in the washing machine drain you will use a pipe auger (snake). Start at the roof plumbing vent and drop cable to roughly 10 or 15 feet past the actual drain. If there is a clog present, the snake will bring up a chunk of debris. Remove it from the top of the vent and discard.
The drain hose is visible toward the bottom of this washing machine. It is held in place by a clamp or a couple of screws.
Remove the drain hose from the back of the washing machine. This is normally held in place by a clamp or a couple of screws. When a drain backup occurs, pieces of debris can lodge in the hose, causing clogs and odors.
Soak the hose in a bucket of warm bleach water.
Soak the drain hose in a bucket of warm water mixed with 1 cup of bleach. Look to see if the line is free of obstructions. Run a small length of clothes hanger through the hose to clear any hard debris.
Reattach drain hose and connect to drain pipe.
Reattach the drain hose using a screwdriver or pliers. Insert the hose into the washing machine drain. Be sure it is all the way into the drain opening.
Run the washer through a full cycle with 2 cups of bleach added.
Cycle the washer with warm water and 2 cups of bleach. The bleach will help remove any odor-causing particles in the machine and drain hose. Running the washing machine through a cycle will help flush away any remnants of the drain pipe clog.
Oct 12, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
My washing machine wont drain or do the final spin.
  1. 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
May 20, 2010 | Frigidaire ATF6000ES Front Load Washer
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Fisher pakel washing machine is not draining or spinning what should I do?
The valve is stuck or dirt is in it. To fix blow in the drain hose of the washer about 3-7 psi enough to hear the air bubbles in the bottom of the tank, it might take more then one shot you can blow with the mouth but not with a air hose at 50 psi the valve and hose will not like it. It has always fixed mine, good luck. To check run in spin the last led red the water should run out.
Nov 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
LD light
something is clogging your drain pump
Oct 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you drain a top Whirlpool load washer (not HE type) for storage?
remove the drain hose clamp and remove the drain hose
gently lay the washer on its back keeping the rear of the console 2 inches from the floor until all water stops running out of drain hose connector
stand back upright reinstall drain hose and clamp and store
Jun 13, 2008 | Whirlpool Washing Machines
LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Jun 09, 2008 | LG WFT1071TP Top Load Washer
Water flowing back into washer after wash
There is a back flow valve attached to the outlet port of the drain pump. It is just a small rubber flap. This sometimes comes loose or remains open due to debris and allows the water in the drain hose to flow back into the machine after the drain pump shuts off. It can be checked by removing the drain hose from the pump inside of the machine. You will lose all of the water in your machine (about 1/2 gallon)when you do this so be prepared with a bunch of towels.
Feb 14, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
