Question about Microsoft Windows XP Professional
What is a second level menu that is accessed using a menu command?
  • 26 Answers
Commands displayed in the start menu that have arrows on the right indicate that a submenu is available for a command. A submenu is a second-level menu.
Ex. "My Recent Documents" usually will have an arrow to the right of it. When you access your recent documents, you are actually accessing a submenu.
Posted on Sep 10, 2009
  • 205 Answers
A Second Level Menu item is simply a menu item that appears when you click one of the top level menu items. For example Start ->"My Recent Documents" or "Programs" usually have an arrow at the right of this menu item. When you rollover mouse on these menu items you'll see your recent documents or program shortcuts, you are actually accessing a submenu.
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Trying out program library. Cannot find "FRAC" command within the menu system or owners manual... can you help?
First of all you have a key marked [a b/c]. It is in the first column of keys, below the [X,theta, T] key and above the 7 digit key. Its second (shifted) function is [d/c] These two keys are used to enter mixed numbers and improper fractions.
The command is also accessed from the menus.
  1. In Run screen press [OPTN]
  2. Press [F6] to move to next page of menus.
  3. Press [F4:NUM]
  4. Among the menu Tabs at the bottom of screen there is the Frac Menu.
  5. Press [F3:Frac] to access it.
Sep 23, 2010 | Casio CFX-9850G Plus Calculator
Reprogam alarms & key less entry
SECTION 419-01A: Anti-Theft — Perimeter 2002 Explorer/Mountaineer Workshop Manual DESCRIPTION AND OPERATION Anti-Theft —Perimeter The perimeter anti-theft system consists of the following:
  • driver door disarm switch
  • vehicle security module
  • keyless entry remote transmitter
  • door ajar switches
  • liftgate ajar switch
  • liftgate glass ajar switch
  • hood ajar switch
Anti-Theft —Passive The passive anti-theft system (PATS) contains the following components:
  • theft indicator
  • encoded ignition key
  • PATS transceiver module
  • powertrain control module (PCM)
  • standard corporate protocol (SCP) communication network
Principles of Operation
The PATS uses a specially encoded ignition key. Each encoded ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code out of over 18 billion, billion combinations.
The passive anti-theft system (PATS), also known as SecuriLock ®, uses radio frequency identification technology to deter a drive-away theft. This system is known as SecuriLock® in North America, Safeguard® in the U.K., and PATS in Continental Europe. Passive means that it does not require any activity from the user.
The SecuriLock® System (PATS) is not compatible with aftermarket remote start systems, which allow the vehicle to be started from outside the vehicle. These systems may reduce the vehicle security level, and also may cause no-start issues. If equipped the remote start system must be removed before investigation of PATS-related, no-start issues.
Each encoded ignition key must be programmed into the vehicle's powertrain control (PCM) before it can be used to start the engine. There are special diagnostic repair procedures described in this section that must be carried out if a new encoded ignition key is necessary.
This system contains a new feature named Unlimited Key Mode. This feature allows a customer to program more than eight keys to the vehicle if they request it. Each vehicle in Unlimited Key Mode is set up with a special Unlimited Transponder Security Key. This allows all the customer vehicles to share the same keys, but no other keys from outside can be used to operate the vehicles. For an individual customer, any randomly selected Security Key is acceptable. Refer to Unlimited Key Mode Programming in Key Programming Switch State Control in this section.
The PATS transceiver module communicates with the encoded ignition key. The module is located behind the steering column shroud and contains an antenna connected to a small electronics module. During each vehicle start sequence, the transceiver module reads the encoded ignition key identification code and sends data to the PCM.
The control functions are contained in the PCM. This module carries out all of the PATS functions, such as receiving the identification code from the encoded ignition key and controlling the engine enable. The PCM initiates the key interrogation sequence when the vehicle ignition switch is turned to RUN or START.
All elements of the PATS must be functional before the engine is allowed to start. If any of the components are not working correctly, the vehicle will not start.
The PATS uses a visual theft indicator. The indicator will prove out for three seconds when the ignition switch is turned to RUN or START under normal operation. If there is a PATS concern, this indicator will either flash rapidly or glow steadily when the ignition switch is turned to RUN or START. The PATS system also flashes the theft indicator every two seconds at ignition OFF to act as a visual deterrent.
The PATS will be activated and will disable the vehicle from starting if there is a:
  • incorrectly encoded ignition key
  • damaged encoded ignition key
  • unprogrammed key
  • non-encoded key (key has no electronics)
  • damaged wiring
  • damaged transceiver
  • damaged PCM
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Key Programming Using Two Programmed Keys NOTE: This procedure only works if two or more programmed ignition keys are available and it is desired to program additional key(s). If two keys are not available, follow the procedure in Key Programming Using Diagnostic Equipment in this section.
NOTE: PID SPARE_KY must be enabled for this procedure to operate. If this PID is not enabled, follow the security access procedure above and select SPARE KEY PROGRAMMING SWITCH: ENABLED.
NOTE: If the programming procedure is successful, the new key(s) will start the vehicle and the THEFT indicator will illuminate for approximately three seconds.
NOTE: If the programming procedure is not successful, the new key(s) will not start the vehicle and the THEFT indicator will flash. If the programming procedure was not successful leave the ignition switch in the RUN position for at least 30 seconds then repeat the key programming procedure from Step 1. If the failure repeats, refer to Diagnosis and Testing to review the DTCs and carry out pinpoint tests as necessary.
NOTE: A maximum of eight ignition keys can be programmed to a passive anti-theft system (PATS) equipped vehicle. If more are needed, refer to Key Programming Switch State Control in this section.
NOTE: If the steps are not carried out as described, the programming procedure will end.
NOTE: Ignition keys must have correct mechanical key cut for the vehicle and must be a PATS encoded key.
NOTE: If the vehicle is in unlimited key mode, this spare programming procedure still functions. Any two keys that can start the vehicle may be used to program in an additional unlimited key.
  1. Insert the first programmed ignition key into the ignition lock cylinder and turn the ignition switch from OFF to RUN (maintain the ignition switch in RUN for three seconds).
  1. Turn the ignition switch to OFF and remove the first key from the ignition lock cylinder.
  1. Within seconds of turning the ignition switch to OFF, insert the second programmed ignition key into the ignition lock cylinder and turn the ignition switch from OFF to RUN (maintain the ignition switch in RUN for three seconds).
  1. Turn the ignition switch to OFF and remove the second key from the ignition lock cylinder.
  1. Within 20 seconds of turning the ignition lock cylinder to OFF, insert the unprogrammed ignition key (new key) into the ignition lock cylinder and turn the ignition switch from OFF to RUN (attempt to start the vehicle).
  1. If it is desired to program additional key(s), repeat the key programming procedure from the beginning.
NOTE: The security access procedure is utilized to obtain passive anti-theft system (PATS) security access. PATS security access must be granted to erase ignition keys, enable/disable unlimited key mode, and enable/disable the spare key programming switch (PID SPARE_KEY). The security access procedure invokes an inherent 10 minute time delay prior to granting security access during which the diagnostic tool must remain connected to the vehicle. Once security access has been granted, a security access command menu is displayed which offers various command options. (For additional information, refer to Powertrain Control Module (PCM) Configuration Command Index).
NOTE: Once security access has been granted, multiple security access commands should be executed (if necessary) prior to exiting the command menu. This avoids the carrying out of an additional security access procedure and the associated 10 minute time delay.
  1. From the diagnostic tool Ford Service Function (FSF) card, enter PCM. Select SECURITY ACCESS. This procedure will take 10 minutes to carry out, during which the ignition switch must be in RUN and the diagnostic tool must be connected to the vehicle.
  1. After the 10 minute security access procedure has been completed, a new menu will be displayed with command options. Select only those functions necessary before exiting out of this menu. Once exited out of this menu, the security access procedure must be repeated again to carry out additional commands.
Oct 01, 2009 | 2002 Mercury Mountaineer
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
I have an American Telecom cordless phone model UA2020EB. As this is being used as an extension in a small, but oddly laid-out apartment, I want to shut the ringer off. (One ringing phone is enough to...
Here's how:
1. Hold the menu button long enough until it beeps;
2. You'll see "Menu"; press 1
3. You'll see "ring:on"
4. Press the Edit button; the "on" flashes;
5. Move the "up" or "down" button once; the "off" flashes;
6. Press the Save button: you're in business and Thou shalt not be bothered by the phone ringing ever more!
Mar 06, 2009 | Lands Phones
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
PCS-1
Reset password sony pcs-1
PUSH ENTER button).
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
Microsoft Windows XP Professional Logo
473 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
