Question about Kenmore Dryers
Dryer takes long to dry cleaned vent hear burner go on but not for long thi is a gas dryer kenmore 70 series
  • 63 Answers
Coils ($30) or High limit thermostat ($40) need to be replaced. Try the coils first. Shut off the power, can’t get it wrong.
Posted on Sep 10, 2009
  • 415 Answers
To know if the vent is for sure cleaned unhook the dryer and start in timed cyc using high heat and see how long it runs does it run longer than when hooked up to vent if so vent is still restricted if not then the blower housing/lint screen is also plugged
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
Hello, My Kenmore 70 serie (model 110.72712101), will not heat up. Cleaned filter and exhaust vent. Any suggestions will be of great help. Thanks!
The ignitor is probably bad not aloowing the gas valve to come on and ignite the gas to heat the dryer. The ignitor is a flat bimetallic element that heats up when the dryer is turned on to light the burner to heat the dryer. It is usually located in the lower left section of the dryer near the burner assembly. It has two wires usually white going to it with a plug in connector on the end.
Jan 18, 2010 | Kenmore 73952 Gas Dryer
Hello I have a Kenmore gas dryer model# 1107282210 and the dyer seems to give off a little heat but then I it will stop giving of heat and the clothes will take very long time to dry. Now I cleaned the...
HI, Check the following to address this issue further.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task. The blower housing should be disassembled, and cleaned in this case.
2. Thermostat(Secondary Cause)- Highly unlikely in your case, but possible
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 17, 2009 | Kenmore 73952 Gas Dryer
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). Searspartsdirect.com carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, repairclinic.com may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Aug 17, 2008 | Dryers
Kenmore Gas Dryer-70 Series is condensating and doesn't heat up
reck vent starting behind dryer then to outside try drying a load with vent disconnected may get warm but will prove or disprove vent problem..water is from clothes and is recondenseing because there is no escape to outside
Jul 02, 2008 | Kenmore 63942 Dryer
Very long drying time
ck vent system if vent not oper it can cause flame roll out and shut off unit also ckd flame sensor on side of burner
Jun 01, 2008 | Kenmore 73952 Gas Dryer
Kenmore 70 series,does not dry
Check the vent pathway. Perhaps the theromstat is sensing high temp due to restricted air flow and kicking off.
Oct 16, 2007 | Kenmore 93042 Gas Dryer
Dryers Logo
69 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
