What is the ''Local Network'' light for on the 2 Wire 1800GH Gateway?
    Master:
  • 441 Answers
That is the light for the LAN connection or your wired computers
Posted on Sep 10, 2009
Ethernet (wired) connection to computer works but "wireless" light does not come on and my laptop cannot locate a wireless access point or network device. It has worked in the past but after...
You will need to get a hold of att. They will need to have you unplug the 2wire and then reconnect. They will need to reset the gateway from their end. good Luck.
Sep 07, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have a 2 Wire network adapter on my desktop pc
If you can see many Wi-Fi nets at your area, try changing the settings especialy the channel transmition for your net.
Stelios.
Feb 21, 2010 | Computers & Internet
2 wire gateway..trying to go wireless....shows excellent signal but limited or no connectivity.
1. Try to determine whether you can connect to the Internet
Start -> Control Panel -> Network and Internet Connection
-> Network Connections -> Right Click Local Area Connection
-> Properties -> Internet Protocol (TCP/IP) ->
Use the following IP Address,
IP Address: 192.168.0.2,
Subnet Mask:255.255.255.0,
Gateway: 192.168.0.1
2. Reset modem and rebooted the computer
3. Check cables if they are properly installed unplug and replug
4. If issue where not resolve contact your ISP service to check if it's the connection or hardware issue " ISP service has a tool that can run a line test determining where the broken connection is."
Nov 15, 2009 | 2wire (1000-000057-000) Modem
Were is the i.p address for the 2 wire so i could put it on my Nintendo dsi
check on your pc - go to network connections locate your local connection go to status and then support - your gateway ip is the 2 wire that u need to input on your ds the default password is the number on the side of the 2 wire...
Sep 17, 2009 | 2wire 2700HG-B Router (2700HGB)
My D-Link Xtreme G DI-624 worked quite well for 5 days -- then failed to connect with Internet while I was using it 2 nights ago. "Network Connection Disabled" was the message. Can you tell me which cables...
From modem's ethernet, connect the wire to the router's Internet/WAN port. From your PC, connect the wire to port 1 of the router. If it says network connection is disabled, right click on Local Area Connection and click on Enable.
Jun 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Connection of HP PSC 950 All-In-OneInkjet to Wireless N network
since your printer dont have NIC or network card..there are 2 option to connect it to your local network
Option 1
Go to Control Panel
Select Printers and Faxes
Right Click on the Printer icon
Select Sharing
then Configure it
Option 2
Buy Print server Port (Wired or Wireless)
depends on cable interface on your printer (USB or Parallel)
Mar 13, 2009 | HP PSC 950 All-In-One InkJet Printer
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Hep
No, it's normally on the router side not the adapter
Sep 11, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Gateway 505GR not showing LAN line for internet
assuming it's XP,right click my computer>properties>hardware tab>device manager, then look down list for network adapters, if its there click the '+' sign, then right click on the network adapter and select uninstall.
Restart pc and the network card will be found and the driver automatically installed.
It should now be in network connections, if not reply back
Aug 15, 2008 | Gateway 505GR PC Desktop
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
